-   -   drivers front universal joint removal (http://www.jeepforum.com/forum/f12/drivers-front-universal-joint-removal-1529411/)
bigboss408 05-28-2013 07:05 PM
i'm looking for some pics on how to remove the diverside front universal the old one is clicking,
RustedWrangler 05-28-2013 07:16 PM
No pics for you, but you will need to remove the axle, so wheel off, hub bearing off, 36mm nut that holds axle in place on hub bearing off remove axle then replace the ujoint. You can do the whole thing in less than an hour if you have everything you need on hand when you start.
bigboss408 05-28-2013 07:23 PM
do i need to replace the oil seal or bearing
fratis 05-28-2013 10:05 PM
21 Attachment(s)
4.5" angle grinder with cut-off wheel.
Firefyter-Emt 05-29-2013 08:17 AM
95 Attachment(s)
This is the BEST way to remove a U-joint by far! I have used this trick for years and its amazing!
Old4X 05-29-2013 09:55 AM
There is a write up on it. THe trick to popping the hub loose with a socket is clearly shown.
Easy job, no seal to replace, just don't drag the axle stub across the seal.
bigboss408 05-30-2013 07:32 PM
is there a link showing this trick
Old4X 05-30-2013 07:46 PM
YJs are old. Everything you have to fix has already been done and likely recorded in the FAQs,
Look here:
http://www.jeepforum.com/forum/f12/a...a-30-a-360209/
The time now is 02:43 PM.
