driver side turn signal - JeepForum.com
post #1 of 12 Old 11-07-2006, 09:29 PM Thread Starter
cody11ca
i turn on my driverside turn signal and the light turns on but does not blink. the passenger side works fine no problem. Ideas? Its a 93 yj
cody11ca is offline
post #2 of 12 Old 11-07-2006, 09:54 PM
Jeeples
Jeeples's Avatar
Burned out bulb?
Could also be the flasher, if I remember correctly, I think that there are 2 of them in the fuse block.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #3 of 12 Old 11-07-2006, 09:55 PM Thread Starter
cody11ca
bulb works fine, i guess i will have to check the flasher.
cody11ca is offline
post #4 of 12 Old 11-07-2006, 09:58 PM
Jeeples
Jeeples's Avatar
So you turn the signal on and the light comes on but it just doesn't flash?
That sounds like the flasher to me, unless I misunderstood you.
Jeeples is offline
post #5 of 12 Old 11-07-2006, 10:05 PM Thread Starter
cody11ca
thats exactly what is going on. so i guess i gotta figure out where on the fuse the flasher is. Would you know?
cody11ca is offline
post #6 of 12 Old 11-07-2006, 11:30 PM
HotDogWater
mine was on the fuse block by the parking brake if i remember... cylindrical shaped silver thingy
95 Rio Grande 2.5L -- stock with 30x9.5 ATs
HotDogWater is offline
post #7 of 12 Old 11-08-2006, 11:25 AM Thread Starter
cody11ca
thanks, i will check that out today.
cody11ca is offline
post #8 of 12 Old 11-08-2006, 11:28 AM
Jeepfreak81
Jeepfreak81's Avatar
IIRC if it's this way on the jeep, but one flasher controls the right and left signals, the other flasher is for the Hazards... I could be thinking of one of my other cars though....
Sounds like a burned out left signal to me, turn on the headlights and hazards and walk around looking for a dim/burned out one -- don't forget the side marker
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #9 of 12 Old 11-08-2006, 11:34 AM
gary1
gary1's Avatar
Check to make sure both the front and back bulbs are lighting up...
If one is burned out the other will just light but not flash... Not enough current to trip the flasher...
gary1 is offline
post #10 of 12 Old 11-08-2006, 12:18 PM
HotDogWater
fyi-
http://www.jeepforum.com/forum/f12/turn-signal-problem-317700/
post #11 of 12 Old 11-08-2006, 12:28 PM
Redskinswin
Sorry to hi-jack the thread but i have a similar issue. My rear driver side works and flashes fine, but the front light and the dash panel light do not come on.
Thoughts?
2012 Wrangler. Stock, for now.
Redskinswin is offline
post #12 of 12 Old 11-08-2006, 12:58 PM
JaySpencer66
Oh yeah!! Lots of thoughts, but some are politically oriented and I will keep them to myself here!
For the lights on the dash, I had an issue with mine. My signals blinked outside but the indicators would not inside. My bulbs were good inside too, I had recently changed them and tested them too. What I had to do to fix them was take off the cover over the lights, two screws in a hard to get at angle above the steering wheel, and then I removed the cover over the speedo and tach, a few more screws above and below them too.
With all the plastic removed the pod or blister that the lights are in is exposed. You can then take out the two or three screws that hold it to the metal which will let you pull it away far enough to get your hand behind it. I am sure there is a modular plug some place behind the dash to let you take the pod/blister off, but I did not look for it because I had enough room to work. If you do not, take a look under and release the cable from any fasteners or clips to get some slack. You only need an inch or so if that much.
With all this done I turned on the turn signals and just wiggled the fittings behind them until they came on. I did the left first, got it working and then the right. With them both okay I held my breath and carefull put the pod/blister back in place and reassembled the dash. Weeks later and I am still okay.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
Member #1 of the "I Hate Torx Club!"
~anyone with a Jeep is an automatic member, and anyone can be member #1~
JaySpencer66 is offline
Driver Side Side Marker and Turn Signal Corroded JeepnBlake TJ Wrangler Technical Forum 3 11-29-2009 10:27 AM
Turning signal (Driver Side) Shinitenshi TJ Wrangler Technical Forum 6 09-02-2009 12:36 PM
keep blowing turn signal filament in parking light bulb on driver side...what the... bortz1892 TJ Wrangler Technical Forum 6 03-29-2009 01:15 PM
Driver side rear turn signal -- no signal --chris-- YJ Wrangler Technical Forum 5 02-23-2008 07:43 PM
driver side rear turn signal issue - where is the ground? bigstinger YJ Wrangler Technical Forum 4 01-28-2007 08:00 AM
