Driver side door lock not working from outside - JeepForum.com
post #1 of 11 Old 07-23-2013, 04:42 PM Thread Starter
finchula
Hi, my 1991 YJ locks and unlocks from inside on the driver side, but when i turn my key on the outside nothing happens, with the door taken apart i can see what is wrong, at least i think what is wrong.
the image on the left is my passenger side where the key works from the outside, and the door locks and unlocks from the inside (so it all works as intended)
the image on the right is my driver side door and you can see it is just missing that rod looking piece to connect from where the keys turns to the actual lock mechanism
any idea what the part is called? or where i can get it?
finchula is offline
post #2 of 11 Old 07-23-2013, 05:01 PM
metalhead
2011 WK
I am a mechanic at a jeep dealership so that's where I got it from. There is a Z shaped bracket that is on the lock cylinder and the rod hooks to it. The part number is 55026850 which is for a 94 wrangler. Not sure if the part number is the same for your model year. Quadratec may have it also.
metalhead is offline
post #3 of 11 Old 07-23-2013, 05:29 PM
cojab
Did it work for you before? If so I would bet you still have the bar rattling around in the bottom of your door and the plastic clips that hold it in place are broken. (Also probably in the bottom of your door) I had to replace mine also.
cojab is offline
post #4 of 11 Old 07-23-2013, 06:45 PM
YJ475
If you find the rod, and it's just the plastic clips that are broken, you can just put the rod back in, and with a pair of pliers, bend the ends of the rod over farther, so it never falls out. Did that with mine a few years ago, and no problems since.
YJ475 is offline
post #5 of 11 Old 07-23-2013, 06:47 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I doubt someone stole it. Look in the bottom of the door.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #6 of 11 Old 07-24-2013, 07:54 AM Thread Starter
finchula
the rod is not in the door :\
finchula is offline
post #7 of 11 Old 07-24-2013, 01:49 PM
remmons
The plastic rod retainers are notorious for cracking or breaking. I was lucky enough to locate my rod at the bottom of my half door. Too bad that's not the case for you though.
Another option to explore if you can't locate a rod is to simply pull one from a XJ in the salvage yard, lay it beside your passenger rod, and bent you a new rod. 9 times out of ten this method will work.
Robert.
remmons is offline
post #8 of 11 Old 07-24-2013, 02:14 PM
SeanB95YJ
your door has locks?
and you use them?
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #9 of 11 Old 07-24-2013, 03:03 PM
remmons
and you use them?
I had thought the same thing too, but I had refrained from saying this.
My half steel doors have locks, but I have never locked my Jeep.....yet.
Robert.
remmons is offline
post #10 of 11 Old 07-24-2013, 03:16 PM
JeeperDon
JeeperDon's Avatar
If all you need is the rod and clip, make the rod from simple steel rod (use the other side as a tempate), and buy the clip (get two).
Web Admin for
post #11 of 11 Old 07-24-2013, 03:27 PM
glturner39
and you use them?
Was wondering how long before someone said this...
glturner39 is offline
door lock , lock mechanism , not working
