Driver side door gremlin - JeepForum.com
post #1 of 4 Old 04-20-2010, 02:54 PM Thread Starter
malone_703
Hey all,
I've fixed the actuating rod in my 95 YJ on the driver side several times. The interior handle fails to open the door from the inside. I've never had a problem until now. This latest fix I used an actuating rod from a wreckers that appears to be bent to clear the window mechanism. This latest fix has introduced a metal on glass scraping noise as I roll down the window. Also as the window rolls down the actuating rod tries to push the interior handle out of its mount. Do I need to bend the rod a particular way or does the window mechanism need work? Thanks in advance for any advice.
malone_703 is offline
post #2 of 4 Old 04-20-2010, 05:08 PM
southbound
Originally Posted by malone_703 View Post
Hey all,
I had the same problem with my door. If your window rolls up and down without the rod in place, then it's just a actuating rod bent out of whack. I had to bend the rod slightly, then snap it back into the door. I would then check the handles (both inside and out) and then roll the window up to ensure there was no binding. If it did bind, I made a mental note of the contact area by looking down inside the door to see which area of the rod was hitting against the window regulator.
It took around three tries to get it right, but once I bent the rod the right way it worked flawlessly. I would also recommend hitting all the inner door mechanics with plenty of WD40 to make sure everything works smoothly. Pay special attention to the rod clips that hold the rod in the door handle. Put some WD40 or grease on them to keep them well lubricated. I broke a few of them over the course of a year. I lubed them up and haven't had any issues since.
I hope this helps ,
5.7L Hemi TJ Build: http://forum.aev-conversions.com/showthread.php?t=7434
southbound is offline
post #3 of 4 Old 04-20-2010, 09:10 PM Thread Starter
malone_703
Even with the actuating rod out of the door it still makes a scraping noise. I've never had this problem before but I think it's weird how rolling down the window tries to pull the interior handle out. All of the mechanism for rolling the window is on the opposite side of the scratching. I'll play with it tomorrow once I figure out if the battery's dead or if it's something else (I know the battery is unrelated, but my wife tried to drive it earlier and it wouldn't start. .)
post #4 of 4 Old 04-22-2010, 08:15 AM Thread Starter
malone_703
Fixed it. I stripped the door, cleaned the window mechanism and sprayed it with white grease. Once it was all re-assembled it works fine now, my window is still scratched up though.
door , scraping , window
driver side door bent dagoober YJ Wrangler Technical Forum 3 10-26-2009 02:02 PM
driver side door won't unlock Karmann TJ Wrangler Technical Forum 3 09-21-2008 10:10 PM
How would you fix this? (driver side door handle) esad_b TJ Wrangler Technical Forum 14 07-10-2008 06:52 AM
Driver side door won't come off jeepramnauth TJ Wrangler Technical Forum 6 02-29-2008 04:54 PM
Rubber piece for driver side door bradb511 TJ Wrangler Technical Forum 1 02-27-2005 11:15 PM
