Driver seat repair help needed - JeepForum.com
post #1 of 5 Old 09-25-2011, 10:01 PM Thread Starter
1992jeepsahara
I have a 1992 sahara jeep wrangler that has a broken driver seat mechanism. The seat slips into a partially reclined state and will not "catch" in any other position. Based on phone inquiries, the "jeep" shops in my area have all told me to buy a new seat. I want to stay true to this jeep and keep original seats but fix the recline issue. Any thoughts?
1992jeepsahara is offline
post #2 of 5 Old 09-30-2011, 05:34 PM
4to1YJ
Had the same problem with my 94 YJ... I sprayed a little PB Blaster in the mechanism and worked it back and forth. It finally latched. But I will say that it will still mess up if I move it. I am able to get it to latch again without spray. Some times it just does it on it's own and some times I have to help it by pushing down on the lever. If it needs a new seat maybe a "you pull it" place would help you keep it "original" enough. Hope this helps.
4to1YJ is offline
post #3 of 5 Old 09-30-2011, 05:36 PM
4to1YJ
Oh also some times moving the back of the seat with the latch on the back of the seat helps too.
4to1YJ is offline
post #4 of 5 Old 09-30-2011, 06:04 PM
bill8bud
To be honest. Run out to a local pick and pull junkyard on a 1/2 weekend and get to seats from a Cavilier for 40 bucks. Put them in so you pull your stockers fix the issue.
I will bet you will never look back once you have the replacement seats in. I was in the same boat I wanted to get mine fixed also. Once I changed seats my back and rear felt so much better I will never go back to the stockers.
http://www.jeepforum.com/forum/f12/r...u-used-490426/
bill8bud is offline
post #5 of 5 Old 10-03-2011, 06:58 AM
mfalik
mfalik's Avatar
If you want to stay true to the factory Sahara seats, I would try to find some used factory seats (Ebay or Craigslist or www.car-parts.com ). If the seat mechanism is in good shape, but the seat covering is in bad shape, have it re-upholstered by an automotive interior repair shop. I had my Sahara seats re-upholstered for $300 (per seat).
MichiganTech Mechanical Engineer Alumni
1994 Wrangler Sahara - Jeep Project
2003 Dodge Ram 1500 (new truck)
2007 Mazda CX-7 (the new commuter car)
2005 Mitsubishi Lancer (Rear Ended - TOTALED)
1998 VW Beetle (SOLD)
1988 Jeep Cherokee Limited - (SOLD)
mfalik is offline
