Driver's Side Axle Seal - JeepForum.com
post #1 of 11 Old 06-02-2010, 07:38 AM Thread Starter
xdgt03
I searched dozens of threads and I could not find the info I am looking for.
Can the driver's side axle seal on a dana 30 be changed without removing the carrier? I have to replace both the passenger side and driver's side after having changed my u-joints and now both are leaking. Typical.
I have the threaded rod/nut and washers system ready to go.
Also, I read a thread that recommended moving the threaded rod side to side between tightening the nut so the seal rocks back and forth as it seats. Is this a good idea?
Thanks
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #2 of 11 Old 06-02-2010, 07:42 AM
jbolty
jbolty's Avatar
No. Carrier comes out for that side.
If the seal is rocking then it's not going in straight. There is NO extra room for movement.
jbolty is offline
post #3 of 11 Old 06-02-2010, 09:14 AM Thread Starter
xdgt03
That's what I thought too. Thanks
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #4 of 11 Old 06-02-2010, 10:04 AM
YJake
Agreed.
When I did both of mine a month or so ago, I used the perfect sized socket and a long 1/2" drive extension to tap it into place. No leaks that I know of yet.
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #5 of 11 Old 06-02-2010, 10:14 AM
jbolty
jbolty's Avatar
Get at least one extra seal. You will almost certainly ruin one trying to get it in on the passenger side.
Since you will have the carrier out it would probably be easier to put in the pass side seal by passing some sort of bar all the way thru the axle tube from the drivers side. Position yourself to guide the business end and steer the seal into place while a helper taps on the other end. The threaded rod method works ok, but the real challenge to that is finding something that is exactly the right diamter and is strong enough to pull in the seal. Plus while doing it you can not actually see if it's going in straight.
jbolty is offline
post #6 of 11 Old 06-02-2010, 11:58 AM
pasinbuy
I was the one that recomended the tapping the threaded nut side to side. Not allot but just a little tap ( about a 1/8 inch to 1/4 inch or less). I found this out after ruining two seals that it helped keep the threaded bar and the seal to go in straight. By applying pressure evenly to the seal sides.
True there is no room but getting the seal started is the challenge. Once the seal is started it can only go straight
If you ruin a seal or two try it, it helped me.
pasinbuy is offline
post #7 of 11 Old 06-02-2010, 02:34 PM
fitbmxseries1
1987 YJ Wrangler
i know i wrecked one trying to put it in using a threaded rod and nut and washer set up. it was easier to just pound it in with lots of extensions and a perfect sized socket.
fitbmxseries1 is offline
post #8 of 11 Old 06-02-2010, 04:19 PM Thread Starter
xdgt03
Thanks guys. Well I had to go to the hardware store to get another washer because the first one I got was exactly the same size as the inside diameter of the metal portion of the passenger side seal. The one the hardware store had was about 1/4" too big around. It also was a 1" diameter hole. So I took two other washers to reduce the size to the threaded rod i had and tack welded them together. Then I took the whole thing to the grinder to get the outside diameter the right size. In the end it worked perfectly using a block of wood with a hole drilled through it on the outside. It seemed to seat perfectly and does not leak. However, I'm not certain how you can determine if the seal is completely seated no matter what way you do it. I guess you know if it doesn't leak.
Thanks for all the replies.
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
post #9 of 11 Old 06-02-2010, 04:34 PM
jbolty
jbolty's Avatar
nice work. As I recall the seal seats about 1/4 inside the lip; you should be able to see it from inside the disco housing after it's in there.
more often than not those seals leak from dragging the axle over it after changing a ujoint or some other task.
jbolty is offline
post #10 of 11 Old 06-02-2010, 05:09 PM
pasinbuy
That is so true. I was carefull as hell pulling the axle and still had to go back in and replace the seals.
They just get old.
pasinbuy is offline
post #11 of 11 Old 06-02-2010, 06:08 PM Thread Starter
xdgt03
Yeah, the lip is about 3/16" but between the flex in the washers (even though 3 were tack welded together) and the fact that the threaded rod did turn a bit even with 2 nuts on the washer side, I couldn't determine if I had done it enough. So I just turned it until I thought I might damage the seal.
BTW, I used a tie rod fork to remove the seal. It took me about 1 minute. I know some people have had some trouble removing these seals. The fork worked perfect. Plus they're cheap and good for removing tie rods too.
1994 Wrangler YJ
/l ,[____],
l---L--''lllllll''-
()_) ()_)--o-)_)
2.5L
31x10.5x15 BFG MT
xdgt03 is offline
Seal driver for front axle seal, disconnect side sequel YJ Wrangler Technical Forum 24 01-24-2010 06:05 PM
passenger side axle seal 91YJRockCrawler YJ Wrangler Technical Forum 8 09-24-2009 07:31 AM
Passanger side axle seal is bad AGAIN 94YJEEPER YJ Wrangler Technical Forum 18 03-16-2009 04:45 PM
Front axle leak driver's side! HELP!!! norton2608 YJ Wrangler Technical Forum 4 06-27-2008 07:54 PM
Passenger side axle seal --bad again SublimeJeep TJ Wrangler Technical Forum 8 09-27-2004 01:06 PM
