Driver door problems - JeepForum.com
post #1 of 3 Old 01-11-2014, 07:15 PM Thread Starter
Pdro130
The window on my drivers side door won't stay up and the crank won't work, thinking it came off the track.. Having to use a wedge in the window to keep it up. Any way to take the inside of the panel off or am I stuck getting a new door? Thanks!
Pdro130 is offline
post #2 of 3 Old 01-11-2014, 07:22 PM
jokerchief462
No it's all repairable.
Pull the handles and the door panel off
Drop window down carefully
You should see how it is attached at the bottom
If it is just off the track get the vent window assembly out if the way
Top side of hard door on the frame work screws for the vent window remove them and one lower on the door frame holds the lower end of the framework for the vent window and window track
From there wrestle it back in place
Reassemble
But be in a good mood not in a hurry and have lots if patience
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 3 Old 01-14-2014, 04:26 PM
Myjeep1986
check out the following: justjeeps.com
Go to the home page and click on jeep service manuals; follow drop down selsction to Body Components. scan from pages 178 through 185 of the 211 and you will see the method to disasemble the door panel and parts for the window.
Myjeep1986 is offline
