Driveline Vibration with cv shaft - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Driveline Vibration with cv shaft
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 03-12-2014, 06:27 AM   #1
mtidwell
Does this look like it needs to be pointed up more?
I know its supposed to point right at the output.
Looks pretty close. I have 2.5 degree shims in it.
Guessi can try 4-6.
Just wanted another opinion.
The Fireman
mtidwell is offline   Reply With Quote
Unread 03-12-2014, 06:33 AM   #2
Jeffro06
October 2012 TJOTM
Jeffro06's Avatar
Yes it needs to go up.
You might need 8-10 degree shims. Steel, not aluminum. Best thing would be to have the perches cut off and welded back on where they belong.
Member of JGW (Jeff's Gone Wheeling) and IndyORV
My Old YJ Build My Mods My YouTube Channel
Shortcuts to key points in my build: MTRk's OME 2" HD Lift Antirock Skidrow steering box & radiator skids LoD rear bumper
Rokmen Mercenary bumper w/Superwinch Rokmen sliders Skidrow engine skid Rampage Top CB set up
Custom trunk Rokmen 1" Billet spacers JJ track bar Rokmen Adjustable Control Arms Currectlync Steering
Rokmen Trail Corners Metalcloak Overlines Kentrol Hood Latches JK Turn Signals Xenon 4" Flat Flares Hood Decal Duratracs
Derale Tranny Cooler DieHard Factor 55 Thimble Ten Factory Front Chromo Shafts
Get your build sheet here.
Jeffro06 is offline   Reply With Quote
