Drivebelt question - JeepForum.com
post #1 of 6 Old 09-05-2011, 11:34 AM Thread Starter
sd846
Drivebelt question
How do you adjust the tension of a drivebelt in 2.5L 4Cylinder engine and if anyone has a diagram that would be great
sd846 is offline
post #2 of 6 Old 09-05-2011, 12:31 PM
moonshinefuel
Loosen the upper and lower front facing bolts, around the back side looking down behind down through the air box/filter, there are two more bolts you have to loosen. Then around the front side again, on the lower right side there is the tensioner bolt which adjusts belt tension.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 6 Old 09-05-2011, 12:46 PM
notmyj
The bolts he talking about are on the power steering pump.
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone "upgrades" a D35, an angel looses its wings."
"Dizzy" - What SnoopDog would call a Distributor if he was a mechanic. I cringe every time I hear this moronic term
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x10, 37's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline
post #4 of 6 Old 09-05-2011, 01:39 PM Thread Starter
sd846
ok thx
sd846 is offline
post #5 of 6 Old 09-05-2011, 02:16 PM
dmblair
And there is a good chance they are going to be seized up. I've seen numerous threads on them being locked up. Good Luck!
dmblair is offline
post #6 of 6 Old 09-05-2011, 02:52 PM
tdewit
A1. Get some PB Blast and keep them soaking wet for a day or so before attempting to loosen the bolts. Don't forget to spray the tensioner bolt. If you look behind the pulley, you'll see it's got a square threaded nut, that's the one that will be solidly rusted.
tdewit is offline
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
Drivebelt (serpentine) Length question PDXTJ TJ Wrangler Technical Forum 0 09-30-2010 05:07 PM
quick connecting rod question and tourqe wrench question???? johnrezz YJ Wrangler Technical Forum 2 10-18-2008 07:20 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
