drive shaft yoke leaking - JeepForum.com
post #1 of 4 Old 06-05-2011, 06:51 PM Thread Starter
danny2go
Where can I buy a seal for the drive shaft where it comes out of the t-case? I have tried all the usual parts stores and can not find one.
danny2go is offline
post #2 of 4 Old 06-05-2011, 09:56 PM
lil_joe
I just bought 3, 2 from Auto Zone ($8 each) and one from Napa ($7 each), long story, you need to tell them its the rear seal for the transfer case, you can also get them from Morris 4x4 ($10) online
Mike
____
lJeepl
--[.]IIIII[.]
Obsession is a word the lazy use to describe the dedicated
HER's: 92 YJ 4" RC 1.5 RC Booms, 1" BL on 33's
MINE's: 97 ZJ 5.2 Upcountry Limited Project 2" RE BB on 265/75 Mud Dogs, Locked front LSD rear, 242 swapped T-Case, RC Quick Disco's
lil_joe is offline
post #3 of 4 Old 06-05-2011, 10:00 PM
MoparFreak69
Just tell them you need a rear output shaft seal for your t-case. If they cant find it they are 1D10T's and you probably should find another store to go to.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #4 of 4 Old 06-06-2011, 01:10 AM
Opihi59
from here it gets rough
Opihi59's Avatar
If you're replacing that seal, take off the rear housing and replace the bushing in there as well. It's best to replace both the seal and the bushing and it doesn't add much to the job. There's a writeup in the FAQ on it, I didn't beat mine out, I used a press with a socket just the right size but didn't take photos at the time. Clean up the slipyoke with some fine steel wool so you don't have any rough spots on the slip yoke that will grind up your new seal.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
slip yoke drive shaft ? MisfitSeven TJ Wrangler Technical Forum 2 02-25-2010 05:58 PM
Rear drive shaft yoke leaking !!!!!! jmccabe YJ Wrangler Technical Forum 12 12-09-2009 12:57 PM
8.8 Yoke / Drive Shaft U-Joint? ech0sh4y YJ Wrangler Technical Forum 1 11-12-2008 09:49 PM
NP231 leaking from CENTER of rear output shaft yoke Spike702 YJ Wrangler Technical Forum 2 09-06-2007 12:10 AM
drive shaft yoke got pulled out of TC, what do i do!?!?! youngjeeper11 YJ Wrangler Technical Forum 11 12-22-2004 03:47 PM
