Drive Shaft Question????? - JeepForum.com
post #1 of 4 Old 02-13-2013, 05:27 PM Thread Starter
daman297
1987 YJ Wrangler
Hey guys I finally have my news transmission in and looks great. I went with the NV3550 along with my original 231 that I added a SYE to. Im staying with the original Dana 30's and the front shaft fit perfect. I know with the SYE the rear drive shaft will be different and it appears to be a very extreme angle. My YJ is a 87 with a SOA and the original 258. The question is with this information can I call and order a new drive shaft from someone or do I need to take it to a shop and have them custom fab one??
daman297 is offline
post #2 of 4 Old 02-13-2013, 06:18 PM
jokerchief462
Call Tom Woods or Adams drive shaft they are on the web and can answer all your questions and tell you which measurements they need to make a custom shaft. Or you can look around locally for a driveline shop. It's not rocket science but the pinion angle thing with the Jeeps needs to be understood. You might just have a place local.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 4 Old 02-14-2013, 06:19 PM Thread Starter
daman297
1987 YJ Wrangler
thanks that answers my question.
daman297 is offline
post #4 of 4 Old 02-14-2013, 06:52 PM
Mark05059
if you set your pinion angle on the rear end before installing your sye you may need to shim to get the correct pinion angle.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
