Drive shaft falling out and other concerns - JeepForum.com
post #1 of 9 Old 07-20-2004, 06:39 AM Thread Starter
sbcvulcan
Just purchased a 93 with 159K. Looking over records for repairs and see that at one time drive shaft fell out. Is this an unusual event? What would cause this?
Looks like U joints have also been replaced a few times, is this common for even regular driving wear and tear? What happens to the transfer case that makes this a Jeep repair issue and is it costly to repair?
I know lots of questions, but you all have lots of answers, yes?
sbcvulcan is offline
post #2 of 9 Old 07-20-2004, 10:28 AM
CanukYJ
CanukYJ's Avatar
Does it have any lift? Jeeps 'driveshafts' falling out is DEFINITELY not a common thing UNLESS they prev owner put a good sized lift (3.5" or more) and did not put a slip yoke eliminator kit on (search the forum for "SYE*"). Without an SYE kit the driveshaft will over-extend the yoke and if you flex the rear end to it's limit it will actually pull the driveshaft right out of the transfer case. hth
My jeep has only ever killed 3 things, a cat, a deer, and my wallet. What's the problem officer?
1992 Red YJ. Lifted, locked, and loaded with beer (Disclaimer: This doesn't mean said driver endorses drinking and driving, please enjoy alcohol responsibly and do not operate any vehicle of any kind, thank you....)
Thanks to the price of gas here ($4.25 a gal) I just bought a mountain bike, 0" of lift, 0" of travel, MT's, locked rear axle, oh yeah, it's the sh#$.
CanukYJ is offline
post #3 of 9 Old 07-20-2004, 10:40 AM Thread Starter
sbcvulcan
It does not have a lift, it looks to be mostly stock. I am unfortunately not aware of how and where the vehicle was previously driven so I am viewing the repair receipts to see if the Jeep has any repeat or alarming issues that I am hoping are resolved. I do hear it is inexpensive to fix a Jeep so if anything is wrong....
Thanks for reply
post #4 of 9 Old 07-20-2004, 10:55 AM
MugZy_YJ_94
ka-mai
MugZy_YJ_94's Avatar
2004 KJ Liberty
replacing the u-joints is not expancive. here they run at 18 euros a piece with a grease nipple. probably a lot cheaper in the US.
the driveshaft falling out is defenatly not a know jeep problem. like canuk sad, running over 3.5 suspension lift may cause this, but only at full artilulation. so my geuss is that, eve, with lift, with the rear traction bar in place, this cannot happen. athere is however a more common drivline problen when lifts are installed: driveline vibrations deu to exessive drivshaft angles. both problems realy only have on good solution: the slip yoke eliminator. if you cant make out if your jeep has lift or not. see wath tire size in on it, or post a pic. i'm sure some can make a good estemate of life by seeing a pic.
good luck
Now in the soccer mum class. Missing the YJ, but the KJ isn't bad...for now.
black jeepclub #35
MugZy_YJ_94 is offline
post #5 of 9 Old 07-20-2004, 10:59 AM
CanukYJ
CanukYJ's Avatar
Jeeps are really easy to fix, well yes and no. Jeeps are very easy to fix as long as you can take the time to learn, they are MUCH easier to fix than most cars\vans and other trucks but you have to buy a factory service manual and take some time to learn. Of course big things (like tranny rebuilds) are still hard(er). Since it had no lift but the driveshaft 'came out' I would put my money on a ujoint that went bad, blew out and the driveshaft of course dropped when that happened. This is NOT a regular occurance and sounds (if that is the case) more like neglect, a ujoint will make a lot of racket, clunking, and squeeling (normally) before it blows up so he may just have no known what it was until it was too late. Jeeps are addictive, although they can be frustrating, they are a lot of fun in the end, prepare to learn a lot more than you anticipate hehe.
CanukYJ is offline
post #6 of 9 Old 07-20-2004, 11:02 AM Thread Starter
sbcvulcan
service manual
[I am definetly into learning to do it yourself as it looks easy to get in and under the jeep. My only struggle will be rusted on pieces I can;t get off. Seems as though there are all sorts of Serveice manual offers out there, what would be the best purchase with best illustrations?
post #7 of 9 Old 07-20-2004, 11:15 AM
CanukYJ
CanukYJ's Avatar
Settle for nothing less than a FSM or factory service manual, get the one for YOUR YEAR of jeep. Search ebay or call your local dlr, they are around, and although they are a bit pricey they are the ENTIRE schematical\procedure\everything down the lug nuts break down of your jeep. I bought a chiltons manual and the thing barely told you how much oil to put in, I've got my FSM and it is the jeep BIBLE. They are worth more than their weight in gold. Awesome that you want to learn about jeeps, it saves a lot of money AND you can say you did the work yourself. Best part is half the time you don't even have to jack the thing up hehe.
CanukYJ is offline
post #8 of 9 Old 07-20-2004, 12:05 PM
YJeepYnot
YJeepYnot's Avatar
Broken U-joint today
Well I broke the u-joint in mine today. Had a 3.5" BDS lift installed less than 50 miles ago, with the t-case drop installed also. Had some vibes, thought it was normal, but this morning on the highway the driveshaft broke loose from the rear diff. Since it was the u-joint and not the shaft "falling out" would you recommend and SYE, with CV driveshaft, or just repair the u-joint.
YJeepYnot is offline
post #9 of 9 Old 07-20-2004, 01:47 PM
gigihurt
gigihurt's Avatar
The first thing I would try is using angle shims under the spring perches. It probably doesnt need much to stop the vibration and adverse wear on the ujoint. Its also a hell of alot cheaper than a SYE.
gigihurt is offline
I have a drive shaft problem=2 drive shafts in less than one week!!!!!! machoman YJ Wrangler Technical Forum 14 12-24-2010 08:39 PM
Concerns on cutting down a rear drive shaft wakingside YJ Wrangler Technical Forum 6 09-16-2009 05:27 PM
Can't get my drive shaft off of the output shaft, any tips/tricks? Dmcastino TJ Wrangler Technical Forum 6 07-23-2009 06:02 PM
Canniblize front drive shaft to fix the rear CV shaft? Scotch740 TJ Wrangler Technical Forum 11 11-28-2008 03:33 PM
4 wheel drive concerns AlixxilA TJ Wrangler Technical Forum 5 06-29-2007 02:40 PM
