drive line angles - Page 7 - JeepForum.com
post #91 of 92 Old 02-06-2013, 05:56 AM
Lrasser
rear pinion angle, t-case angle and drive shaft angle. That with the pics makes it a lot easier to see exactly whats going on. Your on the right track but just do one adjustment at a time. Since there is so exact science to this you need to make small adjustments and see what works. Doing one thing at a time allows you to see if you heading in the right direction. Which you are
Lrasser is offline
post #92 of 92 Old 02-06-2013, 12:04 PM
kahanabob
yea dropping the TC a bit more seems in order from looking at last pics. mark the yoke shaft to see how much more it goes into the TC after you do the additional drop. still concerned that it needs to go into the TC a bit more. see the shinny surface, at one time it was in that far.
kahanabob is offline
