drive line angles - Page 6 - JeepForum.com
post #76 of 92 Old 02-05-2013, 03:21 PM Thread Starter
kjg26
kjg26's Avatar
Originally Posted by kjg26 View Post
Ok drop put in today. Went with a 3/4 drop. Took the rear shims out. Put her back on her feet and took more measurements. Looks to be even angles still.
Rear pinion
Attachment 554358
Transfer case angle
Attachment 554361
ok went for test drive today.
Pulled away from the house and up the street...reached 45mph, alls smooth.
Then i put on the brakes, felt like it was binding/catching. Vibrating the stick shift like crazy, not popping out of gear though.
My thoughts...my pinion angle is too low now. When the vehicle slows/brakes the pinion turns down causing binding.
Anyones thoughts.
To recap, i've got 3/4 in trans case drop and no shims. I'm thinking i should have slowed my roll a little bit and waited on ya'lls response, i think i'll be dropping the rear u-bolts again to replace the shims.
Ok y'alls turn.
Thanks!!
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #77 of 92 Old 02-05-2013, 03:28 PM
kahanabob
that's why i posted "do one thing at a time". should be OK after reinstalling the shims...maybe a pic if you can..
kahanabob is offline
post #78 of 92 Old 02-05-2013, 03:32 PM Thread Starter
kjg26
kjg26's Avatar
Am I on the right track with my theory?
kjg26 is offline
post #79 of 92 Old 02-05-2013, 04:28 PM
0verkillYJ
Agreed. When troubleshooting you never change more than one variable at a time.
95 YJ, 2.5 AX15 conversion, 4.0 TB, SOA +1.5", 33" DC Crusher Tires, 8.8 Rear w/welded tubes + LSD, Spartan Locker HP30 Front w/solid axle swap, Rocky Road OTT kit, JKS Disconnects, AA SYE, Teraflex Shock Bar in Rear, 1/2" Boomerang Shackles, RE Add a Leafs, Homebrew Traction Bar, Monstalined in&out, LED Tail lights, 1700 Watt Stereo
0verkillYJ is offline
post #80 of 92 Old 02-05-2013, 04:33 PM Thread Starter
kjg26
kjg26's Avatar
Lesson learned.
kjg26 is offline
post #81 of 92 Old 02-05-2013, 05:58 PM
kahanabob
yoke still looks like not in far enough. maybe put tape around it where it meets the TC then pull it out to see just how much of it is going in.
post #82 of 92 Old 02-05-2013, 07:01 PM
jeepwrangler89
Ok, so can someone help out a rookie here. How does a mml help to correct the rear driveshaft angle? Wouldn't that just raise the t-case also?
jeepwrangler89 is offline
post #83 of 92 Old 02-05-2013, 07:06 PM Thread Starter
kjg26
kjg26's Avatar
It tilts the tc.
kjg26 is offline
post #84 of 92 Old 02-05-2013, 07:07 PM Thread Starter
kjg26
kjg26's Avatar
Okay with the 3 degree shams in place it is significantly better. However on very hard braking I still get the heavy rattle or binding. Do I need bigger shims? Can I stack shims?
kjg26 is offline
post #85 of 92 Old 02-05-2013, 07:39 PM
0verkillYJ
If you got that much play you need to double check how tight you got your ubolts. Spring under should not rotate too much if everything is fastened down all the way. Vibrations should mainly happen under power.
post #86 of 92 Old 02-05-2013, 07:58 PM Thread Starter
kjg26
kjg26's Avatar
They're torqued to 90 ft/lb as per the Rancho u bolt instructions. I'm just speculating as to what is going on.
What I know.
With a 3/4 trans case drop and no shims I have a nice ride with no vibes. On braking I have quiet a racket. Stick bounces all over place but not out of gear.
With a 3/4 trans case drop and 3 degree shims I have a nice ride with no vibes. On light branding nothing, on heavy braking I get the racket again, not nearly as bad.
I'm currently running it with no shocks as I will need to measure and order new ones. I don't think that has anything to do with it but figured I'd make it known
Ubolts are torqued first to 60 ft/lbs then 75 then 90.
I'm thinking ill try lowering the tc a bit more to see If that changes anything.
kjg26 is offline
post #87 of 92 Old 02-05-2013, 08:14 PM
0verkillYJ
I know I have a tc drop from a 4" lift kit and it is 1.5" drop. Kit also came with 3 degree shims. That was a rough country lift. So maybe 3/4 just isn't enough.
post #88 of 92 Old 02-05-2013, 08:30 PM Thread Starter
kjg26
kjg26's Avatar
Ill be lowering the tc a bit more tomorrow.
kjg26 is offline
post #89 of 92 Old 02-05-2013, 09:19 PM
Lrasser
agreed. judging by pics the pinion doesnt look too bad. T-case still looks steep. measurements would help.
Lrasser is offline
post #90 of 92 Old 02-05-2013, 09:45 PM Thread Starter
kjg26
kjg26's Avatar
Measurements of what?
kjg26 is offline
