drive line angles - Page 5 - JeepForum.com
post #61 of 92 Old 01-29-2013, 05:52 PM Thread Starter
kjg26
kjg26's Avatar
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #62 of 92 Old 01-29-2013, 05:53 PM
Lrasser
you need to rear the t-case at the yoke itself. put a socket on the shaft and put the angle finder on the bottom of it.
Lrasser is offline
post #63 of 92 Old 01-29-2013, 05:58 PM Thread Starter
kjg26
kjg26's Avatar
i know i'm probably making this harder than it has to be, but i'm not getting consistant measurements. Can someone make an idiots guide for me? Or at least pictures so i can make sure i'm measuring off the right points.
kjg26 is offline
post #64 of 92 Old 01-29-2013, 06:01 PM Thread Starter
kjg26
kjg26's Avatar
so measure off this point on the t-case?
kjg26 is offline
post #65 of 92 Old 01-29-2013, 06:03 PM Thread Starter
kjg26
kjg26's Avatar
and this for the rear pinion?
kjg26 is offline
post #66 of 92 Old 01-29-2013, 06:21 PM Thread Starter
kjg26
kjg26's Avatar
Ok. Remeasured
kjg26 is offline
post #67 of 92 Old 01-29-2013, 06:24 PM Thread Starter
kjg26
kjg26's Avatar
Tc yoke
Rear pinion with OME 3 degree shims
This is with about a 1 inch drop. I am going to remove the 3 degree shims and check again. Unless yall think that's a bad idea?
kjg26 is offline
post #68 of 92 Old 01-29-2013, 07:06 PM Thread Starter
kjg26
kjg26's Avatar
Transfer case with 1 inch drop
Rear pinion with no shims.
kjg26 is offline
post #69 of 92 Old 01-29-2013, 07:58 PM
Lrasser
looks like there both at 7 deg in the last pictures. are you still getting a vibration?
Lrasser is offline
post #70 of 92 Old 01-29-2013, 08:06 PM Thread Starter
kjg26
kjg26's Avatar
Haven't driven yet, waiting on the drop, ill have it tomorrow if all goes well. Ill post back asap.
kjg26 is offline
post #71 of 92 Old 01-30-2013, 07:20 PM Thread Starter
kjg26
kjg26's Avatar
Ok drop put in today. Went with a 3/4 drop. Took the rear shims out. Put her back on her feet and took more measurements. Looks to be even angles still.
Rear pinion
Transfer case angle
kjg26 is offline
post #72 of 92 Old 01-30-2013, 09:35 PM
Lrasser
how does it drive? what is the angle of the drive shaft?
Lrasser is offline
post #73 of 92 Old 01-30-2013, 09:41 PM
linusb
My original setup when I bought it was 4" RC lift, 1 - 1 1/2 inch TC drop, and a mild shim, maybe 3 degrees. It drove perfectly smooth like that.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #74 of 92 Old 01-31-2013, 03:39 PM
kahanabob
you should do one thing at a time then drive it then do the next thing (rear shim removal) then drive it.
kahanabob is offline
post #75 of 92 Old 01-31-2013, 03:47 PM
mrdeath2000
exactly what kabob said. Wait until you get into having a DC shaft and have to math it out that changing your differential angle also changes the driveshaft angle and will muff up your calculations.
My difference is -5*, but adding 2*'s in shims will put me +1 because of that. Not all shims are equal/exact, some are thicker and raising the axle affects things, contoured vs flat etc. A lot of trial and error.
93' YJ 2.5L, 4.88's, 8.8, E-Locker & LSD
mrdeath2000 is offline
