Drip, Drip, Drip... - JeepForum.com
post #1 of 7 Old 05-18-2008, 04:35 PM Thread Starter
kevin A Whitler
Drip, Drip, Drip...
Power Steering gear box is leaking at the Pitman arm shaft seal. I replaced the seals already once about 2-3 months ago.
I've done the search function to no avail, everything I find is on TJ's.
My question is this:
Any upgrades like the Durango gear box (on TJ'S) that can replace the OEM steering box without breaking the bank.
I really dont want to replace the seals again, the first seal kit didn't last but 2 months or so which indicates other potential problems.
The Jeep has 184,000 miles on it and very little to no slop or play in th steering.
Any advice from the professionals would be appreciated.
Thxs
kevin A Whitler is offline
post #2 of 7 Old 05-19-2008, 02:32 PM Thread Starter
kevin A Whitler
It is hard to believe this many people have looked and read this post and no responses. I would think this would be an easy answer for those who know more than I do about Steering gear boxes. Come on folks, some of you have completely rebuilt your buggies from the ground up, share some of your knowledge please. It would be appreciated by more folks than just me. Ive learned a ton just reading responses to other questions.
Thxs
post #3 of 7 Old 05-19-2008, 03:02 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Kevin--I read your post but have no knowledge or experience on this subject. It is quite likely that the 72 others who have read this to date also don't have anything to offer. Likely someone will chime in at some point if the right forum subscriber comes across your question and has experience. Good luck to you in this endeavor.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 7 Old 05-19-2008, 03:33 PM
TnTRacing28
I have never resealed a P/S Gearbox but if you are going through seals that quick why don't you just get a reman P/S gearbox from the auto parts store? At least then you can get a warranty
/l ,[____],
l---L 0lllllll0-
()_) ()_)--o-)_)
War doesn't decide who's Right? Only who's Left!
TnTRacing28 is offline
post #5 of 7 Old 05-19-2008, 04:08 PM
pat8942
pat8942's Avatar
Well hopefully I can be of some help since I've rebuilt a few boxes in my day.
First question how did the surface of the shaft look?
Any pits or a groove where the seal sits?
If it's not pitted or at least not bad you can clean it up with some fine emery cloth.
If there is a groove in the shaft you can install the seal a little lower or higher in the housing so the seal contacts a different spot.
Thxs
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #6 of 7 Old 05-19-2008, 04:59 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
just get a new box... those seal kits seem to not last in abusive terrain.
tommy lee has a nice steering box.
Lee Manufacturing Co
11661 Pendleton St
Sun Valley, CA 91352
(818) 768-0371
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #7 of 7 Old 05-19-2008, 08:01 PM
Opihi59
Opihi59's Avatar
Thank you everyone for your responses to the OP.
Opihi59 is offline
Mysterious Drip xjGeoff18 TJ Wrangler Technical Forum 2 08-26-2009 06:25 AM
drip drip cake TJ Wrangler Technical Forum 2 05-29-2008 06:56 PM
oil drip Mike Davis YJ Wrangler Technical Forum 7 12-24-2006 10:39 AM
Drip drip it goes tjslawny TJ Wrangler Technical Forum 4 12-11-2003 01:03 PM
A/C drip drew622 TJ Wrangler Technical Forum 2 07-29-2003 07:28 AM
