Drilled windshield bolts out, now what... - Page 2 - JeepForum.com
post #16 of 24 Old 04-09-2013, 03:10 PM
flcracker
To keep the stainless bolts from seizing up, use some anti-seize compound on the threads before you thread them in. I found a small container at my local Ace Hardware. Its a silver paste and has a small brush attached to the lid to apply it with....
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
post #17 of 24 Old 04-09-2013, 04:06 PM
pasinbuy
I understand that for stainless there is a stainless steel anti seize compound.
pasinbuy is offline
post #18 of 24 Old 04-10-2013, 09:20 AM
GrantYJ
OP,
I don't know if you've resolved this yet, but I ran into a similar situation the evening before last. My captured plate isn't stripped, but it popped off during reassembly of my body (I pulled all the body panels except for the tub when I painted). I remembered seeing this post, so I figured that I'd document how I fixed mine.
Initially, I tried to fish the backer plate back into position through the hole that is under the plate that ties the windshield to the dash on the inside. I tried everything from extension magnets to flex handle magnets, screwdrivers to bailing wire and only managed to get p*ssed off in the process, so I took a little bit more aggressive approach. (This method should also lend itself to get to the side that you're having problems with.)
With the windshield folded down, remove a few screws holding on the cowl gasket and pull it back. If your gasket is bad, this is a great time to replace it. Then, make a "Z" cut (see pic). I just used a 4 1/2" angle grinder with a cutting disk. I don't recommend getting as close to the end screw hole as I did, but it didn't cause a problem.
Then, fold the two triangles back and remove the irritating piece of metal.
Now you can place it where it belongs, start a couple of the bolts, and (in my case) bend the retaining tab back down so that I won't have to do this again.
Now all you have to do is fold the "Z"s back in, tack weld a few spots, clean off all the metal and put a little paint on (I had just put my windshield glass back in and didn't want to get paint everywhere, so I just used some glazing sealant as a rust inhibitor). Once the paint is dry (or in my case, sealant), reinstall the cowl gasket and you're good to go.
The nice thing about doing it this way is that it's completely covered by the cowl gasket. It shouldn't cause any leaks or ever be a cosmetic concern.
I hope this helped.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” ― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance: An Inquiry Into Values
GrantYJ is offline
post #19 of 24 Old 04-10-2013, 09:55 AM
flcracker
Originally Posted by GrantYJ View Post
OP,
Attachment 604923
Attachment 604924
Attachment 604925
Attachment 604926
Attachment 604927
Attachment 604928
I hope this helped.
Now that is nice.... can't believe this hadn't been thought of before....
post #20 of 24 Old 04-10-2013, 10:18 AM
GrantYJ
Thanks. I spent about an hour trying to fish the plate back in place before I gave up. This took me less than fifteen minutes from the time I unscrewed the cowl gasket to putting the screws back in. Most of that time was spent trying to decide where to clamp my ground until I slapped myself in the head and threaded one of the bolts for the "tub to windshield" plate back in and used that.
I just wish it had been as easy getting the windshield back up with the new cowl gasket... I thought I'd never get "roll bar to windshield frame" bolts back in. Liberal use of silicon spray on the new cowl gasket helped though.
GrantYJ is offline
post #21 of 24 Old 04-10-2013, 10:28 AM Thread Starter
kostyanj
That's definitely an option but I'm gonna try paracord first to fish it through. I just primed it and don't feel like having to redo work if possible.
kostyanj is offline
post #22 of 24 Old 04-10-2013, 10:42 AM
GrantYJ
I know where you're coming from. If you look at the pictures, you'll see shiny new paint everywhere (I didn't repaint the interior side of the windshield frame, but now I kinda wish that I had). I was stuffing welding blankets and soft worn out denim everywhere I could in an attempt to keep the cutting dust and weld from ruining freshly buffed out paint (the little white spots in the second picture are buffing compound that was cast off the wheel while buffing the driver's side that I haven't cleaned off yet).
I hope that you can fish it through, but take a look at the 4th picture down. You can see the two tabs that are supposed to hold the backer plate in place. There are also a couple of alignment tabs that just stick up. I don't think that I'd have ever been able to get it back in place without cutting the access hole.
GrantYJ is offline
post #23 of 24 Old 04-10-2013, 07:37 PM
brentd711
I managed to get my plates back in position using a pair of strings on each plate but it took me a couple of hours to do it. Very frustrating. Getting them close is easy, getting the bolts started is the real pain. I ended up using a couple of pieces of threaded rod about 6" long. You can stick them through the hinges and angle them a bit to catch the threads on the plate. Thread a nut down the exposed rod to pull the plates up where they need to be to start your Torx into the plate in another hole. Good luck.
brentd711 is offline
post #24 of 24 Old 04-10-2013, 10:04 PM
DirtKar
Maximum Effort
DirtKar's Avatar
Originally Posted by pasinbuy View Post
you cannot weld a nut to a stainless bolt.
Don't tell my stainless torx removal tools that...
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
