drag link help - JeepForum.com
post #1 of 3 Old 09-12-2011, 07:30 AM Thread Starter
ohio79
2011 JK Wrangler
drag link help
I'm trying to center my steering wheel (yes I lnow there are other threads on that, I looked at em) and almost have it straight. I have threads showing on both side of ther TRE but I can't get it to turn any further. My question is should the drag link go all the way out on either end? If so any advice on moving it that little extra. I'm starting to get good pipe wrench impressions on the link from trying. Much thanks
ohio79 is offline
post #2 of 3 Old 09-12-2011, 07:36 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Beyond corrosion, what would prevent them from going in more? Stock drag link?
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #3 of 3 Old 09-12-2011, 08:53 AM Thread Starter
ohio79
2011 JK Wrangler
Threads look good. Factory TRE's far as I know. Are the supposed to go from thread end on the TRE? Fyi I did have to clean the threads. They had grease on em. The wheel got turnes after I removed the swaybar
ohio79 is offline
Tie rod and drag link gotrock88 YJ Wrangler Technical Forum 3 08-12-2011 03:20 PM
do i need new drag link? bigsquat YJ Wrangler Technical Forum 24 11-19-2010 11:07 PM
who has used zj drag link and tie rod? 02OlllllllOTJ TJ Wrangler Technical Forum 6 04-01-2010 07:35 PM
Drag link hits Swaybar link.... 5150 TJ Wrangler Technical Forum 12 07-21-2005 12:10 PM
Drag Link TellyDSP YJ Wrangler Technical Forum 1 11-16-2003 12:25 PM
