Drag link alignment opinion photo attached! - JeepForum.com
post #1 of 14 Old 04-24-2013, 11:30 PM Thread Starter
randall979
Trying to get this thing to quit drifting to the right. It was drifting pretty bad so I put a longer pitman arm on, the drifting is way better but not totally gone. I'm attaching a photo of the drag link, please let me know if y'all would put a little longer pitman arm on. Or any feed back would be great. Thanks
randall979 is offline
post #2 of 14 Old 04-25-2013, 03:29 AM
Mark05059
get rid of your track bar and see if that makes any difference. The drag link angle is good.. I wouldnt change anything there. Get rid of the rear bar as well. You dont need either
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 14 Old 04-25-2013, 03:49 AM Thread Starter
randall979
I took them off before and it was still drifting, so I put em back on. But I am going to take them off again and see if it helps, but I doubt it though. I put the longer pitman arm (you can see in the pic) and haven't tried it without the track bars yet, so that my next thing.
post #4 of 14 Old 04-25-2013, 05:28 AM
Old4X
1990 CJ7
What is your toe-in set to?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 14 Old 04-25-2013, 06:03 AM
Rproject
1987 YJ Wrangler
That pitman arm doesn't appear to be seated very deeply. Just an observation.
As for the drifting, yeah, check your toe in, and how are your tie rod ends?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #6 of 14 Old 04-25-2013, 06:28 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Don't lower the pitman, raise the other end of the drag link with a JB4x4 bracket.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #7 of 14 Old 04-25-2013, 11:12 AM
remmons
Your drag link and track bar should run parallel in order to reduce or prevent "bump steer". This will also affect your steering symmetry.
Here is a helpful link from JP Magazine explaining this;
http://www.jpmagazine.com/techarticl.../photo_11.html
Robert.
remmons is offline
post #8 of 14 Old 04-25-2013, 11:19 AM
jbolty
jbolty's Avatar
Wildly guessing, in no particualr order:
toe in
loose parts
caster angle (do you have long shackles?)
uneven air pressure or tires
jbolty is offline
post #9 of 14 Old 04-25-2013, 01:37 PM
bentvalves
Kill the track bar or add a bracket to correct the angle with the drag link. An axle which is not centered will cause a drift.
bentvalves is offline
post #10 of 14 Old 04-25-2013, 06:49 PM
ROWA
ROWA's Avatar
randall979,
Measure from front to rear axle, you might have sheared the center pin on the spring pack and the axle might have shifted by a slight amount. I would take it to a alignment shop and check caster camber and toe.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #11 of 14 Old 04-25-2013, 09:30 PM Thread Starter
randall979
Toe is good and tie rod is good.
post #12 of 14 Old 04-25-2013, 09:32 PM Thread Starter
randall979
This is good, I'm removing the track bars though.
post #13 of 14 Old 04-25-2013, 09:34 PM Thread Starter
randall979
toe in
loose parts
It was aligned everything is tight, caster is at 8* and the tires were checked and rotated at the alignment shop.
post #14 of 14 Old 04-25-2013, 09:37 PM Thread Starter
randall979
Originally Posted by ROWA
randall979,
It only a slight drift. There is only one adjustment, the toe. I had it aligned a month ago or so.
