double shock mounts - JeepForum.com
post #1 of 5 Old 03-03-2002, 09:54 PM Thread Starter
JYRUS
double shock mounts
any tips on double shock mounts for a spring over yj. advantages/disadvan. how to built where to buy
JYRUS is offline
post #2 of 5 Old 03-04-2002, 04:44 PM Thread Starter
JYRUS
JYRUS is offline
post #3 of 5 Old 03-04-2002, 04:51 PM
RodeoRob
RodeoRob's Avatar
what size tires you running? double shocks are probably not necessary... might even stiffen your ride too much and make it worse.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #4 of 5 Old 03-04-2002, 05:22 PM
Tailgummer
I also doubt the need for double shocks. Just take up space. Use a good adjustable shock such as the Rancho 9000 to increase or decrease the stiffness. Crank them up and they should plenty stiff, even for a SOA.
Good Luck
Chuck
'91 YJ, 4.0L 5sp, Atlas II, RE SOA + 2"BDS, 35" Explorer Xterrains, ARB's & 4.56 gears, WARN 9000i
WWW.4x4xnorthwest.com
Tailgummer is offline
post #5 of 5 Old 03-05-2002, 12:23 AM
kidwired
kidwired's Avatar
what kinf of whellin r u planning?
multi shocks are for baja style (fast desert racing) and mall croozers.
if your rock crawlin shocks do absolutely nothing except possible inhibit your flex.
I have no rear shocks period and the only reason I have them in front is cus I drive my rig daily.
94 yj SOA +3.5", 35" swampers.
kidwired is offline
YJ Shock Mounts theAuthority YJ Wrangler Technical Forum 24 08-17-2009 12:56 PM
boo-boo on shock mounts iwishihad1 YJ Wrangler Technical Forum 8 04-26-2008 08:50 AM
Shock Mounts PaluzTV YJ Wrangler Technical Forum 6 10-08-2007 07:05 AM
Shock mounts for YJ? PONCH YJ Wrangler Technical Forum 1 07-20-2003 10:55 AM
d@mn shock mounts! Quan YJ Wrangler Technical Forum 9 10-04-2002 08:40 AM
