Door Strap Mount - JeepForum.com
post #1 of 6 Old 11-13-2013, 08:37 AM Thread Starter
AristosIV
Door Strap Mount
My 95 yj rio grande drivers side door got caught by the wind and it pulled the mount and screws right out of the door. I've run in larger self tappers but then they pull out also. Does anyone else have this going on? Is there a fix, ideally w/out removing the door panel?
AristosIV is offline
post #2 of 6 Old 11-13-2013, 08:41 AM
grandboost98
Removing the door panel only takes a few minutes. Thats probably the easiest fix too, just use a bolt and nut. But if you really dont want to take the panel off, I guess you could weld it instead
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3 of 6 Old 11-13-2013, 09:14 AM
crackedcornish
I would just use a bolt/washer/nut but I guess if you don't want to do that, you could use rivnuts and a bolt, or just some plain rivets if you can find them long enough
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is online now
post #4 of 6 Old 11-13-2013, 10:02 AM
StanF
You could use rivet nuts. Harbor Freight has a reasonably priced kit.
I would not recommend welding - I saw that repair on a door once, and it looked really horrible.
StanF is offline
post #5 of 6 Old 11-13-2013, 12:12 PM
StanF
Pop Rivets would also work.
StanF is offline
post #6 of 6 Old 11-13-2013, 12:48 PM Thread Starter
AristosIV
Thanks guys !
