Door Speakers - JeepForum.com
post #1 of 5 Old 08-26-2012, 02:51 AM Thread Starter
chuck172
Door Speakers
I'm thinking about installing in-door speakers.
I don't care about taking off my doors, and this seems to be an ideal location.
Any problems with this installation?
chuck172 is offline
post #2 of 5 Old 08-26-2012, 07:29 AM
Rproject
1987 YJ Wrangler
If you do it, put a molex connector between the door and the body, that way if you do decide you want to remove the doors in the future, it'll be easy to do and the next owner will thank you for it.
As for complications with installation, you'll want to measure the depth of the door. Wrangler doors are pretty thin and may not accommodate flush mounted speakers. You may have to surface mount the speakers.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 5 Old 08-26-2012, 08:12 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Originally Posted by chuck172 View Post
I don't care about taking off my doors...
Buy a car
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #4 of 5 Old 08-26-2012, 02:35 PM
Noltz
YJ Wrangler
Your windows may hit the speaker if you mount them inside the door. They go quite low. There's many speaker options, including custom dash's.
X2 on adding a connector. I've seen a couple installs of power windows installed the same way.
-Noltz
'91 Frankenheep YJ. 4.0, 4" BDS, Richmond 8.8, Titan 12k, 35" KM2's, rust.
'88 YJ, 4.2/4.0 head, +4" & shackles, BFG 33's (sold)
Noltz is offline
post #5 of 5 Old 08-26-2012, 06:20 PM
bcusstc
I have half steel ones and the previous owner put speakers in the door..They seem to work good and disco quick with the right connections..
Me personally i like a good sounding stereo and the useless dash ones dont really cut it..I say go for it.
bcusstc is offline
speakers in door chuck172 YJ Wrangler Technical Forum 7 07-27-2012 09:12 AM
speakers in the door? Wrangler11 YJ Wrangler Technical Forum 2 05-20-2012 04:00 PM
'07 Wrangler Unlimited (4-Door) Speakers Info D4SSWME JK Wrangler Technical Forum 0 08-05-2007 06:34 PM
Factory Connections to door speakers rymanrph YJ Wrangler Technical Forum 4 05-14-2007 06:54 PM
door speakers? superswampjeep TJ Wrangler Technical Forum 2 03-20-2007 05:48 PM
