Door Removal question, super quick, super easy....only will take a sec... - JeepForum.com
post #1 of 18 Old 07-16-2006, 04:48 PM Thread Starter
MCTampa
I took the doors off for the first time 2 nights ago and it was great. just had a quick question: to kill the console light and the little buzzer thing, do you just have to pull the wires out of the back of the little door tab? i just don't want to kill my batter.
Daily Driver: 1995 YJ, 2.5l, 5 spd., 31.5's.
Weekend: 1999 Mustang GT, 5spd., Smoked Headlights, MAC CAI, Steeda Strut-Tower Brace, Steeda Tri-Ax, Bassani X-pipe, Flowmaster Catback, FMS 3.73 gears.
MCTampa is offline
post #2 of 18 Old 07-16-2006, 04:57 PM
Leroux
Leroux's Avatar
Thats what I do.
'93 YJ 4.0 i6, 8.8ls, D30 w/Aussie & Alloy USA shafts/disco removed, 4.56's, 3.5" Fabtech (gathering parts for SOA), 5/8 MORE Boomerangs, SYE, Coast Driveshaft, m8000, "Accordion style" Header w/full exhaust, 33" Siped BFG MT's, TJ Flares.
Leroux is offline
post #3 of 18 Old 07-16-2006, 05:23 PM
YJ-Mike
Or use could use a couple of these $10 gadgets from Q-tec:
http://www.quadratec.com/products/13029_100.htm
That way you are less likely to screw up your wiring by connecting/disconnecting all the time.
Mike
Mike
2006 TJ X (Stock - w/ Borla Cat-Back Exhaust)
Built a YJ from the ground up:
- '04 4.0L (4,000 miles), NV3550 (0 miles), NP231 w/ HD SYE (9,000 miles), 33x12.50x15 Pro-Comp AT's, HP D30/8.8 (4.56 gears), ARB Lockers front and rear w/ compressor, hard/soft tops, full/half doors.
-----> Build thread can be read here:
YJ-Mike is offline
post #4 of 18 Old 07-17-2006, 07:00 AM
SimonTuffGuy
[I'm That Good]
SimonTuffGuy's Avatar
I've been connecting and disconnecting my wires for the past year without any problems.
SimonTuffGuy is offline
post #5 of 18 Old 07-17-2006, 07:04 AM
TellyDSP
Poland and PPV!!!!
7 years, no problems. And it's free. $10 QT is $20 shipped.
I did accidentally kick the door pin last time I was wheeling and broke the f-er off.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #6 of 18 Old 07-17-2006, 07:19 AM
mmasuperman12
mine are permantly disconnected. just turn the switch by the headlights when i need to see.
95 YJ 4banger 4 inch RC lift 1.25 inch BDS shackle lift 33" trxus M/T's on black steelies SOLD..DAMMIT!
Jeep drivers who dig Country Music member #12
1998 XJ - beginning the revival.
mmasuperman12 is offline
post #7 of 18 Old 07-17-2006, 07:55 AM
brypten
can't you pop the fuse? maybe thats just the tj
brypten is offline
post #8 of 18 Old 07-17-2006, 07:59 AM
SimonTuffGuy
[I'm That Good]
Telly - before I pulled my plug, I used to remove the grounding screw from the front. It would stop the light for lighting up, but allow the plug to pull out a bit.
Well, once it was pulled out when I slammed the door on it and snapped it in 5 pieces. They're only like $7 from jeepsareus.com, but it was still a pain. Got the new ones in and started pulling wires instead.
post #9 of 18 Old 07-17-2006, 12:13 PM Thread Starter
MCTampa
after reading this post, i just decided to leave them unplugged for good. i mean, the console light really doesn't throw that much light. im going to go out on a HUGE limb and say that I'll be fine without it.
MCTampa is offline
post #10 of 18 Old 07-17-2006, 12:19 PM
arbby
2005 KJ Liberty
Only reason why I keep mine pluged in is because of the alarm. Other than that, I have no use for them
arbby is offline
post #11 of 18 Old 07-17-2006, 07:10 PM
nick94wrangler
Is there any trick to getting the doors off easily? I just got my Jeep about a month ago, got the doors off twice, but have a terrible time getting them off.
nick94wrangler is offline
post #12 of 18 Old 07-17-2006, 08:11 PM
TellyDSP
Poland and PPV!!!!
grease the hinges before putting them back on. Also, make sure you're lifting straight up. I reach through the window and grab the door from both sides, and lift. Should pop out easy after some grease.
-Craig-
95 Rio Grande
07 Ram 1500
TellyDSP is offline
post #13 of 18 Old 07-17-2006, 10:18 PM Thread Starter
MCTampa
the best way to make sure you're lifting straight up is to get you hands as close to the hinges as possible. that way you wont be lifting at an angle. mine took a while the first time i took them off, but i acually just put some petroleum jelly on the pins when i got them out and they've been great since.
MCTampa is offline
post #14 of 18 Old 07-17-2006, 10:24 PM
PhilipJ
PhilipJ's Avatar
I just unplugged the wires, wrapped them in electrical tape and zip-tied them up out of the way. I don't think I've ever heard a buzzer though, even when it was connected.
PhilipJ is offline
post #15 of 18 Old 07-18-2006, 11:30 AM
JaySpencer66
I also scrubbed out my hinges with a piece of abraisive 3m Pad cut to fit in, that was soaked in PB Blaster. i also scrubbed the pins down the same way, and then I flooded it all tieh lithium grease. Make sure you wipe off any extra lithium or it makes a mess of things.
As to the wires and switches, I have heard about people installing cheap toggle switches on any of the wires and screwing them in place. No disco's anymore, nothing to break either.
/l , [____],
l---L--[]lllllll[]-
()_) ()_)----)_)
Member #1 of the "I Hate Torx Club!"
~anyone with a Jeep is an automatic member, and anyone can be member #1~
JaySpencer66 is offline
Anyone with a 3.5" Super Flex and Super Swamper 33s? Danegerous TJ Wrangler Technical Forum 1 03-14-2009 10:49 PM
Flowmaster super 40 vs super 44 vs Cherry bomb extreme wolfstyle TJ Wrangler Technical Forum 4 04-22-2008 01:00 PM
super quick question....bumpers acerabel1 YJ Wrangler Technical Forum 1 03-05-2008 04:34 PM
Superior Super 35 axle and Super 35 Truss? Voodoo1 YJ Wrangler Technical Forum 10 10-24-2006 09:37 AM
Quick and easy door question jeepjunky TJ Wrangler Technical Forum 4 11-09-2005 07:14 PM
