Door rattle - JeepForum.com
post #1 of 13 Old 04-16-2008, 12:17 PM Thread Starter
samsonitesamson
Door rattle
I tried the search but didn't come up with what I needed.... I just got a set of full doors for the Heep, and they rattle pretty bad going over bumps... is there any way to tighten up the latching mechanism? Anyone else have this problem?
When thou walkest through the fire, thou shalt not be burned; neither shall the flame kindle upon thee ~ Isaiah 43:2 ~
Originally Posted by Bnabb View Post
it bolted right up, except one bolt but i didn't need it anyway
samsonitesamson is offline
post #2 of 13 Old 04-16-2008, 12:37 PM
Hockey1
mine rattle, but i just need to adjust the door striker. that and the weld is broke where the window frame meets the lower half of the door just above the door handle.
1990 Jeep Wrangler YJ 2.5
2004 Grand Cherokee Special Edition
2010 Ford F150 FX4
Welcome to America, now speak English!
Hockey1 is offline
post #3 of 13 Old 04-16-2008, 12:55 PM
Stiffler
Mine was the door striker too. It loosens up, so if you tighten the strike it should help. Also, check the screws that hold the housing for the striker too, sometimes they pop out.
Mr. T.
Stiffler is offline
post #4 of 13 Old 04-16-2008, 05:50 PM Thread Starter
samsonitesamson
my weds are cracked too... I guess that's the next project... is there any adjustment in the striker?
post #5 of 13 Old 04-16-2008, 06:59 PM
Hockey1
yes, you can unscrew the bolt with a torx head bit. you can add or remove the washers to adjust the door.
2010 Ford F150 FX4
Hockey1 is offline
post #6 of 13 Old 04-16-2008, 07:33 PM Thread Starter
samsonitesamson
well, I know with other cars I have had that door rattles happen alot when the plastic bushings on the striker break and go missing, did yj's come with that plastic bushing on the striker?!
post #7 of 13 Old 04-17-2008, 03:40 PM Thread Starter
samsonitesamson
post #8 of 13 Old 04-17-2008, 11:42 PM
jcrouch
Door Rattle
I have noticed on my 99 Sahara that when you shut the Driver's door, it sounds like a marble rattling inside the door handle. Any ideas on what that might be?
jcrouch is offline
post #9 of 13 Old 04-18-2008, 04:40 AM
yellow2kgt
Assuming your TJ doors are like mine... There is a metal rod that runs from the door handle down. It has a plastic bushing that it slides through where it runs through a metal bracket inside the door. On mine that plastic bushing popped out of the hole allowing the rod to move around and make a marble like rattle. I just need to see if I can still get that bushing because the plastic clips that hold it in place are worn off.
1990 Jeep YJ 4.2
Howell EFI, BDS 3.5" lift, M.O.R.E 5/8" Boomerang shackles, 1" Daystar BL, 1" JKS MML, TFI, Crager soft 8s w 35" Dunlop Mud Rovers, Ford 8.8, 4.88s, Dana 30 E-Locker, Terra Flex SYE, Tom Woods CV shaft, Warn M8000.
yellow2kgt is offline
post #10 of 13 Old 04-18-2008, 07:59 AM
YJGEEWA
My door rattle had alot to do with the mirrors rattling around inside there housing replaced them no more rattle. So next time your driving grab hold of the mirror and see if your rattle goes away mine did.
Even a fish wouldn't get into trouble if he kept his mouth shut.
YJGEEWA is offline
post #11 of 13 Old 04-19-2008, 02:19 PM
jcrouch
Thanks for the help. I'll probably get in there and take a look at it this weekend sometime. Just haven't had a chance to tear it apart yet. I imagine it's probably something simple like that.
jcrouch is offline
post #12 of 13 Old 04-19-2008, 02:23 PM
areohbe
I had a rattle too, turns out the screw that holds the vertical divider piece (between main window and tiny triangle window) had loosened and that divider was knocking around... when you hear the rattle again, try pressing on that piece and see if the rattle stops.
areohbe is offline
post #13 of 13 Old 04-19-2008, 03:15 PM
93BlackYJ_PC
1988 XJ Cherokee
There is the off chance it could be a marble
93BlackYJ_PC is offline
Full Door Rattle TJShadow TJ Wrangler Technical Forum 10 05-12-2009 12:11 PM
Door Rattle TSB mtbr JK Wrangler Technical Forum 16 02-05-2009 05:35 PM
Door rattle even on the 08s CRASH0577 JK Wrangler Technical Forum 27 04-27-2008 07:06 PM
door rattle.. as well as another one.. esad_b TJ Wrangler Technical Forum 8 04-25-2008 03:12 PM
Rear door Rattle? wingnutt TJ Wrangler Technical Forum 2 11-08-2005 07:00 PM
