door LOCKS - JeepForum.com
post #1 of 8 Old 01-19-2008, 08:46 AM Thread Starter
meatheadz
meatheadz's Avatar
door LOCKS
When I got my 95 yj awhile ago someone had put on a set of hard-doors. However, the jeep did not come with the door key. I have been reading on the forum about getting the tumblers ground to match the ignition key and that they can do this at a dealership. Do I remove the mechanism from the door and take it in? Or can I just take the whole vehicle in? Estimated cost? It sucks always leaving it unlocked since its my daily driver .
thanx all.
meatheadz is offline
post #2 of 8 Old 01-19-2008, 08:53 AM
blue1989yj
blue1989yj's Avatar
Why not just order the door locks seperate and put them in.
Herculined, MC2100, Nuttered, 31" Mud Rovers
blue1989yj is offline
post #3 of 8 Old 01-23-2008, 02:43 PM
PARTSPHIL
Removing the cylinder from the door is half the battle. After that, it is relatively easy. I just did it this past weekend.
1 Remove cylinder
2 Remove c clip and remove lock pawl
3 Remove centering spring
4 Pull center of cylinder out of housing
5 Insert key
6 Use die grinder to smooth off all tumblers that stick out.
7 Re-insert cylinder in housing and make sure it turns with key.
8.Re-assemble in reverse order.
92 YJ - 4.0 - 5spd - 3.5" BDS -5/8" shackles - TJ flares - KOZ cage - WARN sliders - 33x12.50 BFG M/Ts - AA sye (with a woody) - 8.8- 4.11s - Twin ARBs!!
PARTSPHIL is offline
post #4 of 8 Old 01-24-2008, 10:24 AM Thread Starter
meatheadz
meatheadz's Avatar
now thats what Im talking about! New project for this weekend!
Thanks
post #5 of 8 Old 06-11-2015, 05:57 AM
bidderbl
Thanks for the directions. This sounds pretty easy, but i have no idea what some of those words mean. Is there a video of how to do this that anyone has come across?
bidderbl is offline
post #6 of 8 Old 06-11-2015, 10:44 PM
Mechman71
Believe me, it becomes pretty obvious when you have the lock cylinder out of the door and sitting on the table in front of you. Since it'll be your first time, take a picture of the spring on the back so you can put it back on the same way. I'd reverse #4 and #5 too. Sometimes a tumbler and its spring can fall out of the core if there isn't a key in it to keep them under pressure.
It's also good practice to make sure there are no burrs on the edges of the tumbler pins, and to give it a good dusting with graphite lock lube before you reassemble it.
'89 YJ 4.2 5 speed, Spinnaker blue/grey, hard top and doors, vintage fitted rear speaker boxes but otherwise stock and RUST FREE!!
Mechman71 is offline
post #7 of 8 Old 06-11-2015, 11:40 PM
DirtKar
DirtKar's Avatar
bidderbl-
You can also just pull the lock assembly out of one of your doors and take it to a regular locksmith. $12-15 (+ or -) later you will have a key that fits the doors. This is assuming the doors are in fact a pair from the same vehicle.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #8 of 8 Old 06-11-2015, 11:59 PM
Mechman71
Originally Posted by DirtKar View Post
Or...
You can just pull the lock assembly out of one of your doors and take it to a regular locksmith. $12-15 (+ or -) later you have a key that fits the doors. This is assuming the doors are in fact a pair from the same vehicle.
True that ^
Pre-91 doors use a single edge key similar to those used in old Chevys, and a different key for the ignition. Both the size and shape of the holes in the different year doors are different too (meaning you can't drop a later cylinder into an early door and vice versa - believe me, I once tried).
My '89 has the original hard doors, but it didn't come to me with door keys, only one very worn and cracked ignition key. A local locksmith was able to whip up new keys in less than 20 minutes (it was a slow day I guess) for under $20. Worth every penny, since I didn't even have a blank for the door key.
cylinder , door , lock
Door locks rustzuk TJ Wrangler Technical Forum 6 12-15-2007 09:03 AM
door locks chewin'rocks YJ Wrangler Technical Forum 7 12-12-2005 06:21 PM
full door/ half door locks MugZy_YJ_94 YJ Wrangler Technical Forum 2 11-13-2003 05:41 AM
Door Locks lostboy YJ Wrangler Technical Forum 1 11-11-2003 09:07 PM
