Door Latch and Post (90 YJ) - JeepForum.com
post #1 of 7 Old 10-11-2005, 10:24 PM Thread Starter
YJ Newby
Hello All!
Stumbled across this site and it is wonderful! I am new to the Jeep world with my recent purchase of a 1990 Islander. I am steadily learning a few of the little ticks about Wranglers (Carter 2BBL, anyone?) but am overall very happy with it. One thing I noticed, though, is that neither door closes properly. You can firmly shut them, but they flop back "open" about a half inch or so and rattle like crazy while I drive. Is this typical of Jeeps, and if so is there a simple adjustment that I can make to have them close properly? Or, am I in for replacing both latch mechanisms or posts (or both)? Sorry if this is a dumb question, but I have played around with them for hours and cannot figure out how to get them to close properly.
Thanks!
YJ Newby is offline
post #2 of 7 Old 10-11-2005, 10:32 PM
Stangman516
I have the same problem on my jeep. it is pretty common. Try adjusting the stricker (the round metal peice the door latches around when it closes) mine has a big groove in it because it's so old so the door latches catch in the groove and consequently the door does not shut properly. somebody told me that the stricker is adjustable so you could try loosening it and moving it in or just get a new one. hope that helps
and welcome to the site
'95 Mustang GT
'91 YJ 4.0L
/l ,[____],
l---L--?lllllll?-
()_) ()_)----)_)
White Jeep club member #40
Stangman516 is offline
post #3 of 7 Old 10-11-2005, 10:41 PM Thread Starter
YJ Newby
Is the torx slot in the center of the striker where you loosen it? When I try this, the whole post just spins. Should I grab it with a channel lock and try again? Incidently, I know exactly what "goove" you are referring to. I have a very handsome set on my strikers, too.
Thanks!
YJ Newby is offline
post #4 of 7 Old 10-12-2005, 10:12 AM
Wif
Wif's Avatar
I had the same problem with my half doors .. try oiling the catch plate in the door before adjusting anything .. I found that my catch was springing back out a bit and not locking .. after oiling it went in all the way.
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
post #5 of 7 Old 10-12-2005, 08:31 PM Thread Starter
YJ Newby
WOW! How could the remedy be so simple? A couple of shots of WD40, open & close the door a few times, and they are closing as tight as the day it was new.
Thanks!
YJ Newby is offline
post #6 of 7 Old 10-13-2005, 09:54 PM
copscott76
On my YJ, the passenger's side closes all the way, but the driver's side takes a little bit more umph to get the door to shut all the way. Would oiling the springs help this cause? When the door shuts, there is a little gap but doesn't rattle. Any ideas would be helpful.
copscott76 is offline
post #7 of 7 Old 10-13-2005, 10:30 PM Thread Starter
YJ Newby
Lubing the latch assembly sure worked for me. I just opened the door and sprayed the whole latch assembly area with WD40. (NOTE: you will get a lot of black, gunky crud pouring out of the weep holes on the bottom of the door, so be ready to wipe it off the rocker panels - You may also want to put a towel on your seats, 'cuz it kinda sprays when you shut the door the first time or two) I then opened and closed the door a few time and repeated the process. They close tight now with very little effort. I will go ahead and oil them this weekend since the WD40 probably washed away all of the necessary lubrication between the metal-to-metal bits.
( Thanks for the tip 88Jeepster! )
YJ Newby is offline
Where can I find a door latch post? schwebel YJ Wrangler Technical Forum 3 11-20-2009 07:18 PM
Door latch post assembly diagram gkainz YJ Wrangler Technical Forum 5 09-28-2009 10:23 PM
Tailgate Latch/Post TedderX_ TJ Wrangler Technical Forum 10 02-28-2009 09:07 AM
replaced interior door latch, door does not open from inside now! the_art_of_desi TJ Wrangler Technical Forum 2 02-06-2009 04:32 PM
soft door, door latch question ohhpe YJ Wrangler Technical Forum 4 05-05-2006 06:57 AM
