door hinge torx bolts - JeepForum.com
post #1 of 5 Old 04-02-2013, 12:54 AM Thread Starter
chuck172
If I remove the inner door panel, can I get to the back of the torx hinge bolts to heat or spray with pb blaster?
chuck172 is offline
post #2 of 5 Old 04-02-2013, 05:04 AM
StanF
Full door or half doors?
In either case, you'll have enough access to spray PB Blaster in there, but won't be able to do much else. You won't have great access unless you cut a new access hole right behind the hinges.
StanF is offline
post #3 of 5 Old 04-02-2013, 07:51 AM
50rck
My half doors were so seized up that heat and PB Blaster wouldn't work on 3 of them. I had to drill them out, eventually ruining one of the T-shaped backing plates on the inside of the door. No one sells that plate that I could find. I had to get a thick, flat piece of metal from a junk yard and fab it myself. To get to that plate I had to cut a big hole in the inside of the door, and then have someone weld that back on.
1991 YJ, rebuilt 4.0L in spring 2009 at 234,000 miles, no lift yet, slightly offset wheels, 235/75/15 tires for now, rag top, sold the hard top. Over 35,000 miles on the rebuild and counting.
2006 Jeep Liberty. Nothing special, all stock.
50rck is offline
post #4 of 5 Old 04-02-2013, 08:48 AM
StanF
I just drilled out a torx bolt on my full door this past weekend. With a bit of skill (and a lot of luck!), I removed the screw without messing up the backing plate.
If you aren't too far off center with your drilling, a helicoil should be able to repair the backing plate threads.
StanF is offline
post #5 of 5 Old 04-02-2013, 05:15 PM Thread Starter
chuck172
I took off the inner panel, I could spray the bottom hinge easy enough. I drilled a hole for the top hinge. It worked! I'll be replaceing the torx with allen.
chuck172 is offline
