Door Handle rods - JeepForum.com
post #1 of 8 Old 03-12-2009, 08:09 PM Thread Starter
Mark05059
Door Handle rods
Anyone know if you can get the little clips for the door rods. These arent plastic ones they are tin/steel and the rods have threads on them on my sons 95. On my 89 they are plastic and the rod is bent to go into it. I either need to find an early rod with the 90 degree bend or the clip to match the later rod.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #2 of 8 Old 03-12-2009, 09:08 PM
yjislander
They had them at my stealership when I was looking for the plastic ones. My dealer gave me the last of the plastic ones and said that they are a dicontinued part, maybe you will be lucky and be able to still get yours.
illigal™
Christian Jeeper #4
92 Yj on 32's
2015 JKU Sahara Hydro blue
yjislander is offline
post #3 of 8 Old 03-12-2009, 09:09 PM Thread Starter
Mark05059
the plastic ones can be found at many aftermarket parts stores such as pep boys.. autozone... advance auto parts etc... I just cant find the ones that accept the threaded rods as of yet.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #4 of 8 Old 03-12-2009, 09:13 PM
yjislander
My dealership had them, they tried to tell me that was what I needed at first. I would at least try them, unless you wanna make a different setup.
illigal™
Christian Jeeper #4
92 Yj on 32's
post #5 of 8 Old 03-12-2009, 09:18 PM Thread Starter
Mark05059
They had which one... the steel/tin ones?
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #6 of 8 Old 03-12-2009, 09:24 PM
yjislander
Yeah the steel ones, they gave me the rest of the plastic ones because they were a dicontinued part. Then they tried to give me the metal ones as well, but I had no need for them, this was about 3 months ago. If your lucky maybe they still have them at your local dealership.
illigal™
Christian Jeeper #4
92 Yj on 32's
post #7 of 8 Old 03-12-2009, 10:30 PM
4.7stroker
I use copper wire and bend it as required to hold everything together.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #8 of 8 Old 03-13-2009, 05:41 AM
Rproject
1987 YJ Wrangler
Dwayne
I used steel wire, but did the same thing. Why buy what you can fix?
Rproject is offline
How do you take the door handle off of a full door? Gabe TJ Wrangler Technical Forum 14 10-02-2009 07:44 PM
newb help-door handle popped out of door TURBevO8 TJ Wrangler Technical Forum 7 01-28-2009 04:24 PM
YJ Door rods and lock pauls Austin77 YJ Wrangler Technical Forum 3 12-03-2008 05:59 PM
Exterior door handle on full door popping out? JTruel TJ Wrangler Technical Forum 1 10-24-2008 04:19 PM
inside door handle wont open door alecmcmahon YJ Wrangler Technical Forum 2 07-30-2006 06:39 PM
