Door Adjustments! - JeepForum.com
post #1 of 3 Old 04-27-2010, 04:32 PM Thread Starter
Sleuthhound
Door Adjustments!
So yesterday I traded my soft top/half doors, for another jeeper's hard top / full doors, and his doors are quite out of whack on my jeep. The Driver's side is about 1/4" high (where the striker meets the pin), and the passenger side is just a little high.
I know I need to adjust the hinges, and I'm certain I'll figure it out (or search on here for some previously discusses how-tos), but my question is this:
Can I move only ONE of the hinges on each door? I would only need to adjust the top hinge, as there is room for the bottom hinge to drop before it meets the body-hinge, and I believe there's just enough for it to drop and everything line up, if I can move the top hinge 1/4" (Driver side), and maybe 1/8" (pass side)....thoughts?
cheers!
Sleuthhound is offline
post #2 of 3 Old 04-27-2010, 05:22 PM
Leans93
She's my density...
Leans93's Avatar
When I purchased full doors I put the pins in the hinges and as you've experienced the doors didn't line up with the striker. I slowly loosened both door hinges until the striker lined up at which point I latched it to keep it in place. Then I loosened both door hinges even more and moved the door into a nice fitting position and tightened the hinge screws back up.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #3 of 3 Old 04-27-2010, 07:24 PM
K4KAS
If the door lines up with the tub, loosen the striker and adjust it. Not the hinges. If its way out of whack, then yes, you may have to go to the hinges.
K4KAS is offline
tj headlight adjustments flankgent TJ Wrangler Technical Forum 26 11-20-2008 04:24 PM
Any trick or adjustments on a TBI? NEPhillyJeep YJ Wrangler Technical Forum 3 01-30-2007 12:42 AM
Tailgate adjustments drver TJ Wrangler Technical Forum 4 07-01-2006 11:30 PM
Cam Adjustments Andrew F TJ Wrangler Technical Forum 5 05-20-2006 12:23 PM
T-case adjustments igofshn TJ Wrangler Technical Forum 4 07-06-2002 07:07 PM
