"dont go any bigger or you'll snap those axles" - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > "dont go any bigger or you'll snap those axles"
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 08-19-2012, 04:25 PM   #1
0regonjeeper
I had my lift installed by a shop here because i have neither nor the space at my apartment. When it was all done and i picked it up the guy there asked what size tires i would be going with. Its a 4" lift so i told him 33s. He gave me a look and said "dont go any bigger or you'll snap those axles".
Is that accurate? If so, what is it that would break my stock axles. I know that really hard whelling or spinning tires and suddenly gaining traction can do it but is there something about spcifically bigger tires that will do it?
0regonjeeper is offline   Reply With Quote
Unread 08-19-2012, 04:34 PM   #2
deathtrap
your rear dana 35 axle is prone to breakage with larger then stock tires and or heavy use/abuse. lots of info about this on hear.
deathtrap is offline   Reply With Quote
Unread 08-19-2012, 04:36 PM   #3
pete1991YJ
Your buddy is basically correct. The Dana 35 rear is known to be weak, and it has been known to blow even with stock tires and setups. Mine is still hanging in there with 31's but I have a 4-cylinder and I absolutely baby it and go easy on it. Most guys swap in a Dana 44 or the Ford 8.8 out of a 1996 and up Explorer.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
91 YJ 2.5L 5-spd, 31" BFG ATs, mostly stock NO RUST 160K in WNY, Daily Driver
pete1991YJ is offline   Reply With Quote
Unread 08-19-2012, 05:47 PM   #4
USMCBuckWild
All the above is correct. The Dana 35 is known to be weak and prone to failure. That being said I got my Jeep with 38s on D35 behind a chevy 350. It lasted like that for over 2 years (with minimal actual wheeling) I just finished the 8.8 swap into my YJ, it's pretty easy to do yourself, just find a buddy with a welder and you will be golden.
USMCBuckWild is offline   Reply With Quote
Unread 08-19-2012, 05:49 PM   #5
Anticanman
Anticanman's Avatar
Broke two Dana 35's on the street with 31's. It's a crapshoot and I seem to have the worst of luck.
Luck favors the prepared
Originally Posted by squarelight94 View Post
You're the Oprah of jeeps, slap your name on it and it sells like hot cakes!
Originally Posted by jbolty View Post
I would like to thank everyone who thanked Anticanman.
Originally Posted by egodfrey
Well canada is a different story this is american talk here silly :rofl:
Anticanman is offline   Reply With Quote
Unread 08-19-2012, 05:52 PM   #6
UltimatE
Resident Audio Guru
UltimatE's Avatar
The front D30 will handle 33's no problem. It'll handle 35's too if you don't beat it like it owes you money.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is online now   Reply With Quote
Unread 08-19-2012, 05:57 PM   #7
skip11and1
i know ppl that ran 38's on a d35 and no breakage, just don't beat on it. if your stuck you stuck get winched out don/t hammer on it.
2013 Jeep Patriot 4x4 FD1 5spd
2004 TJ Columbia package long armed w/ 33's (Sold)
2005 WK, v6 QT1 (girlfriends)
waiting for the day so I can afford a trail rig
skip11and1 is offline   Reply With Quote
Unread 08-19-2012, 06:01 PM   #8
UltimatE
Resident Audio Guru
UltimatE's Avatar
There was a thread hinting that early yj's that run D35's with large tires with little issues. There was a theory going about a change in metallurgy with the switch from AMC to Chrysler. Whether or not its true, I don't know. But I do know there is an '87 YJ lifted 6" on 37's with a welded D35 running in my club that hasn't broken it yet.
-Matt
White '94 YJ Sport
Unread 08-19-2012, 06:15 PM   #9
seattle_yj
seattle_yj's Avatar
You could always upgrade the rears axle shafts from stock to alloy axles for a quick strength upgrade. That's what I did, and has lasted for 3 years so far. Then keep the old axles for spares.
I think one reason that the d35s break, I've noticed that the wheel bearings seem to wear out quickly, and they actually chew into the end of the axle shaft, wearing it down, eventually snapping. I'm by no means an expert on d35s but that is just what I have noticed on my vehicles.
Most of the more serious folks seem to be doing that 8.8 swap, which seems like it is the hot ticket. I will be doing that shortly.
seattle_yj is offline   Reply With Quote
Unread 08-20-2012, 03:05 PM   #10
jimmybob67
If you do the 8.8 swap do you find one with the same gearing as the D30 ( I have 3.07) or do you have to re gear?
jimmybob67 is offline   Reply With Quote
Unread 08-20-2012, 03:23 PM   #11
Anticanman
Anticanman's Avatar
Usually you find the 8.8 with the gears you want then regear the 30
Unread 08-20-2012, 03:30 PM   #12
bogleparsons
Considering you have 3.07's yea.... what he said.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
_____
/l ,[____],
l---L []llllll[]-
()_)-()_)-O-)_)
bogleparsons is offline   Reply With Quote
Unread 08-21-2012, 09:05 AM   #13
jimmybob67
Was hoping to avoid the re gear since I don't know how and the expense.
"The greatest honor in the world: Picking up a weapon to defend our families and nation against those that have sworn to do them harm.
Unread 08-21-2012, 09:18 AM   #14
bogleparsons
we are all trying to avoid the expenses lol... with that said 3.27, 3.55,3.73, 4.10
thats the ratios the 8.8 came in.
_____
/l ,[____],
l---L []llllll[]-
()_)-()_)-O-)_)
Unread 08-21-2012, 09:20 AM   #15
jimmybob67
What's the average cost of the axle. And a set of gears.
