Don't know where to start - JeepForum.com
post #1 of 7 Old 08-17-2012, 10:02 PM Thread Starter
Dazzle
Hi I just got my second Jeep (first was a CJ7 1985) and I don't know where to start fixing. Some say brakes and suspension first, others say engine and drive train. A bit of info: YJ 1994 2.5L AX-5 Dana 30frt/35rr. It drives but engine has leak in rear main seal. Suspension is shot, gears shift but I can hear the differential clicking. Brakes need new rotors. Passed smog fine. There is so much to do I don't know where to start first. Any suggestions on where to start?
Dazzle is offline
post #2 of 7 Old 08-17-2012, 11:27 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Always, fix safety issues first. Then driveability/streetability next. Then consider mods for other purposes.
Safety issues first--fix what could hurt you or others, the rest will fall into place.
And, welcome to the forum.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 7 Old 08-18-2012, 12:45 AM
rogerv
^ x2 always safety first
If it's not broke- modify it, so it won't break
rogerv is offline
post #4 of 7 Old 08-18-2012, 04:39 AM
roadyrob
1987 YJ Wrangler
X3, safety first, but make a list of repairs needed so you have a plan. I.E. you don't want to do brakes on an axle that needs replacing.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #5 of 7 Old 08-20-2012, 05:51 AM
Rproject
1987 YJ Wrangler
The first thing I did with both of my Jeeps was fluids. ALL fluids. I found many of the squirrels I was hearing running around were actually just old fluid that desperately needed to be replaced. Especially in the t/c and differentials.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #6 of 7 Old 08-20-2012, 11:21 AM
NonRubicon
I agree with Opihi59 - safety first.
Brakes > engine/drivetrain/electrical > suspension.
-It's drivable, but you want to be able to stop safely. Good brakes are necessary.
-Check the condition of the differential, see if there is a locker causing the clicking or if the noise is due to damaged gears.
-The rear main seal - degrease the entire block to determine with certainty where the oil is originating. I thought I had a slow rear main leak until I degreased the engine and found it was all originating from the valve cover, oil filler cap and the distributor. Oil will blow back and drip down at the bell housing from pretty much anywhere.
-The stock suspension on these old Jeeps will pretty much be flat, drivable, but not always desirable. I drove on a bent rear driver's side spring (factory OEM) for a year before replacing the suspension. I think the springs were 20 years old by then. Not that I recommend driving on damaged springs, but it can be done.
NonRubicon is offline
post #7 of 7 Old 09-02-2012, 10:17 AM Thread Starter
Dazzle
Great, so far I've replaced brake front brake rotors and pads, replaced transmission oil, engine oil, rear differential oil (clicking stopped) and cover gasket, lubed tie-rod ends and ball joints. I've checked the ball joint and all linkage for damage or play and found none, checked steering shaft linkage, verified vacuum, and bolted down the hard top better than it was when I got it. Now, I think I will start on replacing shocks and leaf springs and bushings or fix the engine oil leak (rear main seal i beleive). I think suspension is more critical than engine oil leak. The shock cylinders are really rusted and need replacing and the springs and bushings need replacing too. The shackles look good.
Dazzle is offline
fixing , repairs , YJ
Slow Start - Died - No Start - Start ggking7 TJ Wrangler Technical Forum 10 12-04-2011 10:49 AM
TJ Morning Start Fine, Idles Fine, Second start requires throttle to start s4ms0n TJ Wrangler Technical Forum 4 11-17-2011 08:03 PM
Cold Start Turned Into No Start...Problem Resolved...Lesson Learned... tony673 YJ Wrangler Technical Forum 2 10-02-2011 07:49 PM
Can you push start / bump start a TJ? (posts from Boonie Mechanic tricks thread) Wheelin98TJ TJ Wrangler Technical Forum 162 02-08-2011 11:50 PM
Jump start = Volt Meter spikes while driving then wont start AWILD TJ Wrangler Technical Forum 5 02-21-2010 05:37 PM
