Dome Light - JeepForum.com
post #1 of 6 Old 12-27-2001, 10:01 PM Thread Starter
AllanAlxndr
Dome Light
This maybe a stupid question but,
I have a hard top on my '90 Wrangler. I am just curious how the Dome light works. Where is the switch located (thought it was the switch next to the rear wiper switch?) and anything to check why the light doesn't work? I replaced the bulb and nothing?
Any help would be appriciated... Thanks in advance...
Allan
***What do I know, I just cause Problems***
*'90 Wrangler*
*4 Banger*
*6" of lift, (4" suspension, 2" body)*
*33" ATs on Outlaw II's*
*Pioneer DEH3500/CD deck*
*1800WATT Amp w/ Custom Box*
*2 - 8" Rockford Fosgate HEs*
*Cobra 18WXSTII w/ 4' Firestik Antenna*
Member of
AllanAlxndr is offline
post #2 of 6 Old 12-28-2001, 06:40 AM
glm 87 wrangler
the round scroll nob on your dash lights will make them come on when you turn it.Not sure which way but if you make your dash lights brighter and keep scrolling it should come on.
Some people unplug the pin switch by the doors.They do this because if they use soft half doors the dome will stay on.So you may check out this option also.And 2 make sure the plug is pluged into the hard top.It should be
on the driverside back corner.hope this helps
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #3 of 6 Old 12-28-2001, 11:10 AM Thread Starter
AllanAlxndr
Thanks, I will check that out today and let you know what happens. I know forsure that it is pluged in. I will try the dimmer for the dash and see if that is it... Thanks again.
Allan
*'90 Wrangler*
*4 Banger*
Member of
post #4 of 6 Old 12-28-2001, 08:49 PM
cooksterdog
Guys, check to make sure your pin switch is well grounded also. I was having similar prob, and removed switch, scrapped paint from spot where it contacts door frame and reinstalled. it solved the problem, and also made the light MUCH brighter. to turn on the light you should be able to rotate the wheel/knob to the detent and then click on the overhead light.
steve and cookie
cooksterdog is offline
post #5 of 6 Old 12-28-2001, 10:21 PM Thread Starter
AllanAlxndr
Upon Further inspection, The dome light fuse is blown... I will see if this helps and then go from there...
Thanks
Allan
*'90 Wrangler*
*4 Banger*
Member of
post #6 of 6 Old 12-29-2001, 02:08 PM Thread Starter
AllanAlxndr
I bought a new 20 amp fuse for the Dome light on the Fuse box and everything works now. Thanks for all the help.
Allan
*'90 Wrangler*
*4 Banger*
Member of
Interior light issues - dome light and wiring mess liminalhigh YJ Wrangler Technical Forum 0 07-20-2009 08:47 AM
Replacing dome light & LED floor light question MacK JK Wrangler Technical Forum 7 09-30-2008 02:02 PM
Need Help With Dome Light stokesj19 TJ Wrangler Technical Forum 1 05-11-2006 11:04 PM
Dome light sulldoggy TJ Wrangler Technical Forum 5 11-09-2005 07:59 AM
Dome Light. JFM626 TJ Wrangler Technical Forum 11 03-13-2005 01:15 AM
