doing my breaks - JeepForum.com
post #1 of 11 Old 10-03-2006, 02:27 PM Thread Starter
bobbert350
bobbert350's Avatar
doing my breaks
i was reduging my drum breaks today and a whole bunch of crap happened so i decided to wait till tomorrow..while i was driving home i had an idea could i paint my outside of my drums..like use a scratch pad and get them clean then sand and paint or would it be a dumb idea?
bobbert350 is offline
post #2 of 11 Old 10-03-2006, 02:28 PM Thread Starter
bobbert350
bobbert350's Avatar
has anyone tried this before
post #3 of 11 Old 10-03-2006, 02:37 PM
EJames1226
EJames1226's Avatar
Why would you do this?
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline
post #4 of 11 Old 10-03-2006, 02:41 PM Thread Starter
bobbert350
bobbert350's Avatar
dont no...i guess cauz i can. im just talking about painting the outside of them or would the paint disapear and chip as they got hoter
post #5 of 11 Old 10-03-2006, 02:52 PM Thread Starter
bobbert350
bobbert350's Avatar
anyone else no if this would be a ok idea..its also kinda bothering me cauz my drums are a bit rusty well they look fine but the outside is a rusty color and i can see them with the wheel on
post #6 of 11 Old 10-03-2006, 03:22 PM
vader7071
The theory behind it is sound.
Having said that, IF you paint them, use a paint that is designed for high heat applications, specifically brake parts. I know Wal-Mart sell brake caliper paints, I see no reason they shouldn't work here. Or Grill paint for that matter.
Now, back to the logistics. Can you? Yes, always. As me & my buddies like to say, there isn't anything we won't f*** up.
Should you? I see no reason why it would interfere with normal operations, as long as you only painted the outside, which I am sure you already knew.
If you ask me, I would reseach the paint and try it. I see no difference in painting the outer housing of the drum than I do painting the axle housing or the frame.
vader7071 is offline
post #7 of 11 Old 10-03-2006, 03:24 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Brakes....not breaks. And yes, it's fine to paint them. Use a high temp engine paint....or bbq grill paint works too.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #8 of 11 Old 10-03-2006, 03:47 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
It might be best to use a small sand-blaster to get the drums clean of any rust or scale first.
Most of the "HighTemp" paints require a bake-in time - easily done with your kitchen oven. 350 to 400 would be about right.
I bought some silver/chrome VHT (Very High Temperature) paint that I used on a set of headers. It held up fairly well.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #9 of 11 Old 10-03-2006, 04:26 PM
GrimJeeper91
GrimJeeper91's Avatar
I used plain old Rustoleum and it holds up just fine. It's been two or three years and no chipping or flaking. Looks pretty good too...
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
post #10 of 11 Old 10-03-2006, 10:09 PM
drexelsteve
it's like painting a starter...sure you can paint it but why waste the time?
13 Rubi
drexelsteve is offline
post #11 of 11 Old 10-03-2006, 10:29 PM
kent l
I painted mine
You should have no problem. I used rustolem and used a brush to apply the paint. I also used a wire wheel to get the rust off. I use this method on my frame also. It is much easier to get the mud off if the surface is painted.
kent l is offline
breaks on 35s Sidewinder YJ Wrangler Technical Forum 2 05-23-2009 10:49 AM
breaks? not so much joeyrossmiller YJ Wrangler Technical Forum 3 04-30-2009 08:37 AM
New breaks Corey4x4man TJ Wrangler Technical Forum 1 01-03-2007 08:49 PM
breaks breaks and E-brakes YJXtreme YJ Wrangler Technical Forum 8 11-30-2003 08:50 AM
breaks again? my_tj TJ Wrangler Technical Forum 4 10-01-2003 12:24 PM
