Doing 4.0 Swap Now..... Need Help Now !!! - Page 7 - JeepForum.com
post #91 of 157 Old 01-21-2010, 06:38 AM
YJBlues
YJBlues's Avatar
btw, 02 sensor wont keep it from starting, it runs with presets for the first few seconds minimum, 02 reading doesn't affect that to my knowledge. No ecm codes is perplexing, but on the up side, any readings you get before it's actually run will be mostly useless. It will pick up a few things, but if it's indeed "trying" to start, I suspect fuel delivery to be at least one of the issues.
I'm assuming here that it's been confirmed that the ecm is in working order of course, CEL comes on, then goes off after a few seconds, etc. Again I assume to check the read outs, the OP is turning the key, on, off, on, off, on then waiting for the CEL to go out, then however long it takes for the CEL light to start blinking codes, usually 10ish seconds after the CEL initially goes out?
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #92 of 157 Old 01-21-2010, 06:55 AM Thread Starter
cevans87
1992 XJ Cherokee
ok well i'm lost
i tried timing, i've checked fuel, plugs, cps, idle air control valve,
and still nothing...
i wondering if my fuel lines are right ?
this is how i have it hooked up
THE FUEL LINE DIRECTLY IN FRONT OF THE REGULATOR IS MY RETURN LINE... WHICH JUST HAPPENS TO BE THE ONE CLOSEST TO THE FRONT OF THE VEHICLE...
MY FUEL LINE CLOSEST TO THE FIREWALL IS MY FEED LINE
SOUND RIGHT TO ANYONE?
cevans87 is offline
post #93 of 157 Old 01-21-2010, 07:04 AM
YJBlues
YJBlues's Avatar
Originally Posted by cevans87 View Post
ok well i'm lost
put about half a cup of gas in the throttle body and try to start it. You may be trying to debug a system that has nothing wrong with it
YJBlues is offline
post #94 of 157 Old 01-21-2010, 08:58 AM Thread Starter
cevans87
1992 XJ Cherokee
i will try it tonight, but last night when i removed the spark plugs, they were covered with gas, so i cleaned them
i honestly don't know whats going on with it, and i'm about to loose my mind
if it starts when i pour gas in, what do i need to do then ?
cevans87 is offline
post #95 of 157 Old 01-21-2010, 09:00 AM
YJBlues
YJBlues's Avatar
then you make sure your injectors are firing and that there is pressure to the fuel rail, which can be checked by pushing the button in on the schrader valve in the rail.
YJBlues is offline
post #96 of 157 Old 01-21-2010, 09:10 AM Thread Starter
cevans87
1992 XJ Cherokee
there is plenty of presure at the valve, how do i test the injectors ?
cevans87 is offline
post #97 of 157 Old 01-21-2010, 09:16 AM
YJBlues
YJBlues's Avatar
pretty easy, test light can do it. we have two wire injectors right? just connect the testlight between the wires on one of the injectors and crank the engine, it should flash.
YJBlues is offline
post #98 of 157 Old 01-21-2010, 09:32 AM
YJBlues
YJBlues's Avatar
Have you checked for spark at the spark plugs btw? several methods of checking, but I generally just use a timing light. the flash is easy to see.
by your description of the conditions of the plugs and the fact that you can't get any codes from the ecm, I'm starting to wonder if it's working.
YJBlues is offline
post #99 of 157 Old 01-21-2010, 11:25 AM Thread Starter
cevans87
1992 XJ Cherokee
if the ecm is working ?
can you go into a little more detail with testing the injectors
cevans87 is offline
post #100 of 157 Old 01-21-2010, 11:34 AM
YJBlues
YJBlues's Avatar
the injectors are controlled by the ecm, it sends an electrical current to the injector, the injector pumps a burst of fuel into the intake. The wires that connect to the injector carries that current. If there is a signal, the injectors are working. So basically you are simply checking to see if the ecm is sending the current. Testing the injectors might sound like it should be complicated, and it can get more involved if you are trying to find more than if they are just firing, but in this instance, it really isn't any harder than finding out if your coil is getting power. Just check for juice when the motor is cranking across the two wires on one of the injectors.
And yes, I'm starting to wonder if the ECM is doing it's job. But let's test for spark and injectors before we jump to conclusions. though with wet plugs, checking for spark is probably the first test you want to do. If no spark you don't even have to bother checking the injectors yet.
YJBlues is offline
post #101 of 157 Old 01-21-2010, 11:55 AM Thread Starter
cevans87
1992 XJ Cherokee
ok will do as soon as i get home yjblues
cevans87 is offline
post #102 of 157 Old 01-21-2010, 09:01 PM
YJBlues
YJBlues's Avatar
Any word on this?
YJBlues is offline
post #103 of 157 Old 01-22-2010, 08:09 AM Thread Starter
cevans87
1992 XJ Cherokee
ok got it to run from 5-10 seconds... but extremely rough
cevans87 is offline
post #104 of 157 Old 01-22-2010, 08:18 AM Thread Starter
cevans87
1992 XJ Cherokee
went and got new plugs and cap and rotor, tested the injectors, and for spark
cevans87 is offline
post #105 of 157 Old 01-22-2010, 08:36 AM
YJBlues
YJBlues's Avatar
got it to run how? with the half cup of gas or some other way? The results of the spark and injector test?
YJBlues is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
