Doing 4.0 Swap Now..... Need Help Now !!! - Page 6 - JeepForum.com
post #76 of 157 Old 01-18-2010, 08:13 PM Thread Starter
cevans87
1992 XJ Cherokee
oh and i have put a test light at the pump orange wire, i have power...
i put the test light on the black wire, and i got a really dim light... does that mean i need a new ground ?
cevans87 is offline
post #77 of 157 Old 01-18-2010, 10:02 PM
dodger889
Ok you have a bad ground. the ground for that is located behind the e brake peddle on one of the bolts. It comes off the connector that you attached the fuel pump wire to so that should make it easier to find.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #78 of 157 Old 01-19-2010, 09:52 PM Thread Starter
cevans87
1992 XJ Cherokee
ok, got the fuel pump figured out, I dropped the tank a 3rd time, took the pump out and tested it, it was a no go, I beat it around, and put 125psi of air through it and still nothing, so $91 dollars later, we had a pump that worked...
hooked up the battery, primed the fuel system and turned the key, and then turned the key again, then turned the key again and again and again and again and again and still nothing... so i called dodger... after talking to him, we figured out the fuel lines were backwards... i fixed that and then we tried to start it again only to hear a doublebarrel shotgun go off under the truck... so we took the cap off to find we were 180 out, so we played with the timing for about and hour and i think i have it right where it needs to be now, but won't be able to test it untill tomorrow. so I should have a running, roaring, small oil leak from the rear main seal, engine tomorrow. after i get it running, and drive it for about a week to make sure the engine is good and nothing else is needed at this point i will be dropping the oil pan to do only my (in the upper teens) rear main seal... it's become a part of life to me, i've owed 3 jeep cherokee's, 2 wranglers, a loaded hemi commander, a willys 53' delivery van, an original mb3, and a 54 willys truck and anything that has had a 4.0 in it i've always had to replace the rear main... i'm not saying it's a bad motor, i love the 4.0, but for some reason they always go out on me... and just for the record because i read a post last night about mileage anniversary...
1987 Jeep Cherokee Pioneer (Never Rebuilt, Original Everything Except Tires and Rims) - Threw Rod @ 517,862
1992 Jeep Cherokee Sport (Nothing Wrong, No Smoking, No Ticking, All Original) - Replaced @ 442,393 for More Pep
1986 Jeep Cherokee Laredo (2Door, 2.5) - Junked @ 354,772
1988 Jeep Wrangler - 4.2L Still Pulling Strong @ 287,637
1988 Jeep Wrangler - 103,439 Swapped For Fuel Injection
53' Willys - 27,645
54' Willys - 37,274
MB3 - 6,338
Commander - Sold @ 69k
cevans87 is offline
post #79 of 157 Old 01-19-2010, 10:04 PM
YJBlues
YJBlues's Avatar
Don't jump the gun on the rear main, for some reason these 4.0's will weep a bit after they sit a while, may not be permanent.
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #80 of 157 Old 01-20-2010, 05:00 AM
dodger889
Well I'm glad to hear that you are getting that close to getting it to run.
post #81 of 157 Old 01-20-2010, 03:25 PM
dodger889
Here is what I found out about the o2 sensor. Since you have a universal o2 sensor what ever wire you have going to pin 41 (ECM) will connect to the black wire coming from the o2 sensor (sensor feed to ECM) . Pin 4 (ECM) wire will connect to the gray ( grey) wire (sensor ground) . The other two will connect to the white wires( heater) no polarity to those.
post #82 of 157 Old 01-20-2010, 05:23 PM Thread Starter
cevans87
1992 XJ Cherokee
ok o2 sensor is hooked up and still nothing... it's trying to start but it's like the timing is off, i take it off and reset it more than 20 times and nothing , it will get worse and then get better and then not try at all............ any ideas
cevans87 is offline
post #83 of 157 Old 01-20-2010, 05:25 PM
dodger889
Have you tested the fuel pressure with a gauge?
post #84 of 157 Old 01-20-2010, 05:35 PM Thread Starter
cevans87
1992 XJ Cherokee
don't know how
cevans87 is offline
post #85 of 157 Old 01-20-2010, 06:06 PM
dodger889
There is a schroeder valve on the fuel rail that you can use a gauge on.
post #86 of 157 Old 01-20-2010, 08:23 PM
YJBlues
YJBlues's Avatar
pour half a cup of gas in the throttle body and try to start it, if it starts, your problem is in fuel delivery, if it doesn't, it's somewhere else.
YJBlues is offline
post #87 of 157 Old 01-20-2010, 09:18 PM
dodger889
Well when I last talk to him is if hold the throttle wide open it is trying to run. I told him to check the idle circuit
post #88 of 157 Old 01-21-2010, 05:30 AM
YJBlues
YJBlues's Avatar
Yeah, not trying to interfere, you're doing better than I could explaining without being there in person to see it. I'm a little impatient on fuel problems, heh, I always get to the "dump fuel in the throttle body" part sooner than most I guess
YJBlues is offline
post #89 of 157 Old 01-21-2010, 06:16 AM
dodger889
Hey at this point I'm about to my end without actually being there to see what has been done or needs to be done. So any subjection are more then welcome on my part or his. The part that has me baffle is the fact that he can not read the code out of the ECM.
post #90 of 157 Old 01-21-2010, 06:29 AM
Mark05059
sounds as if he doenst have enough fuel pressure to atomize the fuel.. ?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
