Doing 4.0 Swap Now..... Need Help Now !!! - Page 4 - JeepForum.com
post #46 of 157 Old 01-16-2010, 06:23 AM
dodger889
Ok quit using block diagrams I have posted the wires that need to be connected to get you started. If you noticed there are only 4 wires that you need. Have you tied the PDC to the battery? There is a heavy gauge ( 1 or 2 gauge wire that connects the battery to the PDC that is what you power the rest of the jeep except for the starter.
Please post a picture of what you are doing this is getting very confusing .
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #47 of 157 Old 01-16-2010, 06:28 AM
dodger889
Dude you will not get power to the coil untill you are turning the motor over . You are not understanding how the ECM works. Do you understand the ECM takes the control to GROUND means? If I can get my cam to work I will post some pictures for you today.
post #48 of 157 Old 01-16-2010, 08:29 AM Thread Starter
cevans87
1992 XJ Cherokee
i'll take some pictures today, and i understand that i won't have it untill it until it is being turned over, but thats just it when i go to start... i have nothing at the coil , thats why i was going to put the coil on a switched 12v source...
still wondering about fuel pump wiring
cevans87 is offline
post #49 of 157 Old 01-16-2010, 08:37 AM
dodger889
Have you even looked at the wiring diagram that I sent you??
post #50 of 157 Old 01-16-2010, 10:31 AM
jsawduste
2006 YJ Wrangler
Dodger is correct. The ECM looks for a crank signal. If it does not see one it shuts down power to the coil and fuel pump. If you look you will see that one of the coil wires ties into the main splice (green/red on a YJ) that goes to the ASD and the operating sensors. In fact you can trace that wire back to the coil from any of the injectors. It is common with all of them.
jsawduste is offline
post #51 of 157 Old 01-16-2010, 11:48 AM Thread Starter
cevans87
1992 XJ Cherokee
thanks guys... i talked with dodger on the phone for about an hour and we got it figured out.
now the porblem is with the fuel system...
dodger explained to me that using the stock fuel pump externally is not a good idea as it will burn up, and the junkyards are closed today.
does anyone kow of a setup i can use...
i need a self regulated external pump capable of 45psi
anyone know where i can get one
cevans87 is offline
post #52 of 157 Old 01-16-2010, 11:56 AM
YJBlues
YJBlues's Avatar
pretty sure NAPA or somewhere similar would have an inline fuel pump.
I got the dirty, low down, lovin my YJ Blues
Black Jeeps have longer hoods!
YJBlues is offline
post #53 of 157 Old 01-16-2010, 12:29 PM
jsawduste
2006 YJ Wrangler
Dodger is right on the money about using an internal pump externally.
FWIW I used a Mustang V8 internal pump. A couple small mods to the mount inside the tank is all it took to mount it. Now I have 50 some lbs. if needed and plenty of flow. Maybe you could do this ??
post #54 of 157 Old 01-16-2010, 02:30 PM Thread Starter
cevans87
1992 XJ Cherokee
jsawduste what year mustang and what did you have to do... anything to help me out at this point
cevans87 is offline
post #55 of 157 Old 01-16-2010, 02:50 PM
jsawduste
2006 YJ Wrangler
Late model GT/Mach 1. Had to shorten the rubber hose. Solder in a ground wire and add a hose clamp to hold it all together. 15 minutes worth of work, tops. Advance Auto
$45-50 IIRC
post #56 of 157 Old 01-16-2010, 03:05 PM Thread Starter
cevans87
1992 XJ Cherokee
you got the whole thing ?
cevans87 is offline
post #57 of 157 Old 01-16-2010, 03:23 PM
jsawduste
2006 YJ Wrangler
Just the pump
post #58 of 157 Old 01-16-2010, 03:57 PM Thread Starter
cevans87
1992 XJ Cherokee
if i buy a pump and sending unit will i fit right up in my stock tank ?
cevans87 is offline
post #59 of 157 Old 01-16-2010, 03:59 PM Thread Starter
cevans87
1992 XJ Cherokee
jsawduste...advance wants 289 for just the pump for a 2003 mustang gt
cevans87 is offline
post #60 of 157 Old 01-16-2010, 04:45 PM
jsawduste
2006 YJ Wrangler
Dayum, all you need is the pump itself. No sender. You will use the stock sender with no worries.
Link,
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Electric-Fuel-Pumps-Univ-Airtex_3141314-P_N3339K_P|GRP2030P____
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Electric-Fuel-Pumps-Univ-Airtex_3141403-P_N3339K_P|GRP2030P____
Have them check the flow rates. They DO have a spec chart. Pick the higher of the 2
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
