Doing 4.0 Swap Now..... Need Help Now !!! - Page 3 - JeepForum.com
post #31 of 157 Old 01-15-2010, 07:27 AM
dodger889
If I'm not mistaken it orange.
Edit dark blue is the one that runs the ECM which will power the coil.
You are only using about 3 to 4 wires to power every thing for the engine controls
Starter
ECM
power
and a ground
Now the rest of the wired are for sending unit and sensors.
Now you do have the gray wire at the coil to -
and the dark green/orange to the +??
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #32 of 157 Old 01-15-2010, 08:57 AM Thread Starter
cevans87
1992 XJ Cherokee
yes i have grey to - and green/orange to +
cevans87 is offline
post #33 of 157 Old 01-15-2010, 09:21 AM Thread Starter
cevans87
1992 XJ Cherokee
ok so i took off the cover to the ecm... i flash tested a few wires...
blue wire --- pin 9 - - - have power
tach wire --- pin 43 - - - dead
ignition coil wire --- pin 19 - - - dead
is my computer bad ?
cevans87 is offline
post #34 of 157 Old 01-15-2010, 09:30 AM
dodger889
Do you have power to pin 3 on the ecm?
post #35 of 157 Old 01-15-2010, 09:31 AM
dodger889
Oh you will not see a + voltage on the tach or to the coil. the ECM takes them to ground.
post #36 of 157 Old 01-15-2010, 09:36 AM
dodger889
Here is something else take a light from pin 32 ( black/pink wire) to a hot and see if that is working when you first turn on the the key that is your check engine light. This is the one to read codes with.
post #37 of 157 Old 01-15-2010, 09:47 AM Thread Starter
cevans87
1992 XJ Cherokee
i have power at pin 3, none at 32
cevans87 is offline
post #38 of 157 Old 01-15-2010, 10:04 AM
dodger889
You misunderstood me you will not have a + voltage it will be a ground .
Ok let me see if this will make sense to you The ECM takes a lot of the control functions to ground IE coil and the pin 32 you have to supply a + voltage to the otherside of the coil (+) and if you are using a meter or light for testing pin 32 you need to hook up backward to what would be normal. One wire to pin 32 and to a hot voltage to read it. Yes it sound dumb but that is the way the ecm works on some of the control function.
post #39 of 157 Old 01-15-2010, 10:19 AM Thread Starter
cevans87
1992 XJ Cherokee
no i have no ground at 32
cevans87 is offline
post #40 of 157 Old 01-15-2010, 10:41 AM
jsawduste
2006 YJ Wrangler
Correct, the CEL is on a switched 12 volt. Switched in that when the key turns a blue/wht wire sends power to the CEL. The ECM then grounds the circuit and the lights goes off after a few seconds, assuming you have no codes. If you do have a code then the ECM continues to ground the circuit, keeping the CEL lit.
Look for a yellow/black at the ring connector that grounds the engine harness. This is a primary ground for the ECM.
jsawduste is offline
post #41 of 157 Old 01-15-2010, 11:08 AM Thread Starter
cevans87
1992 XJ Cherokee
where is the ring connector
cevans87 is offline
post #42 of 157 Old 01-15-2010, 11:51 AM
jsawduste
2006 YJ Wrangler
On a YJ it connects to the oil dipstick mounting bolt. Has 2 yellow/blacks crimped into one connector. One goes to the ECM and the other goes to the trans harness connector.
On this pin 32. Look for a connection to ground. Not voltage.
post #43 of 157 Old 01-15-2010, 03:59 PM Thread Starter
cevans87
1992 XJ Cherokee
ok went to the junkyard again, got a new 95xj harness and 94 xj ecm
starting over because of all the wiring issues with last harness
cevans87 is offline
post #44 of 157 Old 01-15-2010, 08:28 PM Thread Starter
cevans87
1992 XJ Cherokee
ok another update...
harness is in, ecm is in... everything is hooked up and might i add looks a lot better than last time...
so i had to get a new headlight switch, got it while i was out at the junkyard
i get home get everything in, and hooked up to the battery and low and behold my headlights worked...
everything would seem good right ? wrong.... i don't have the headlight switch in and every circuit on the headlight harness is hot, so now i have to track down where it's getting feed from... any help would be appreciated
cevans87 is offline
post #45 of 157 Old 01-16-2010, 12:14 AM Thread Starter
cevans87
1992 XJ Cherokee
another update....
i tied a positve wire from the xj harness to the dead re 12v source to the ignition... then tied the blue power wire for the computer into the yellow wire at the ignition switch i now i have power to computer, fuse block, starter relay, headlights, tail lights, turn signals, high beam indicator, and running lights... still however no power to the coil... so i'm going to refer back to my big block engine wiring knowledge and run a switched 12v lead to the coil and a ground to the negitive side... if someone see's for any reason I shouldn't do that please let me know.
i am now focused on power to the coil... and tripping the fuel pump relay
can i tie a switched 12v lead to the fuel pump relay, then find the 12v source wire from the relay and run it to my pump ?
cevans87 is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 05:11 AM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 03:42 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 02:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 04:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 04:28 PM
