Doing 4.0 Swap Now..... Need Help Now !!! - Page 11 - JeepForum.com
post #151 of 157 Old 02-09-2010, 09:05 AM
dodger889
Originally Posted by cevans87 View Post
Ok guys I will post pics tonight for the gentleman that is doing the swap this weekend. And as for keeping the 258 and putting a holley on that's all great but the cfm rate for a 4 barrel is way to much for a 258 a motorcraft 2100 is a better carb for the motor and is what was on it when I started. I am very satisfied with the performance and glad I did the swap. I'm doing another one this weekend on a 4cyl, hope it goes just as good in the end since I know exactly what needs to be done now. I appreciate evryones help and as far as the motor goes for anyone reading or interested, the flywheel from a 1987-1990 cherokee motor will not work for 1991 through 1995 ecm and harness save yourself the trouble and get a 92-94 motor and harness and make sure at the bulkhead connector you don't have a purple and white braided wire, this is a clear indication that the harness and ecm have a security system and cannot be used
those just have to be tied together to make them to work.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #152 of 157 Old 02-14-2010, 02:56 PM Thread Starter
cevans87
1992 XJ Cherokee
ok guys, another question...
i've been playing with these guages and can't seem to find out what the problem is. i have 8volts on the volt meter, the fuel and oil presure are both tached out, the temp doesn't show anything... anyone have any ideas
and also i bought the 1991 vss and my speedo cable won't hook up, going to the junkyard tommrow, im going to look for one out of a cherokee and try to make it work, i'm going to take a few pictures tonight and post them up of the jeep and the few things to look for and do during the swap
Built Not Bought #447, 1992 Jeep XJ Supercharged 4.7, 1988 Jeep YJ Auto 4.2L, 2008 Commander Limited HEMI, 1990 Jeep YJ 4.7L Fuel Injected AW4, 1981 Scrambler 304 Auto
I Am The Jeep Surgeon!!!
cevans87 is offline
post #153 of 157 Old 02-14-2010, 06:18 PM
dodger889
The vss is just a pass through for the the cable side. Will it screw on where it comes out of the TC?
post #154 of 157 Old 02-26-2010, 07:19 AM
Bastidjeep
cevans87, Did you ever take any pics of your swap? I'd like to see them if you did.
Bastidjeep is offline
post #155 of 157 Old 02-26-2010, 08:15 AM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
The cable output of the 91 VSS is 5/8" instead of 7/8". Your options are to order a '91 YJ speedometer cable that has the 5/8" at the T-case end, or use an adapter.
Adapters can be found at the junkyard in early (pre-'91) YJs and XJs that have cruise control. The speed sensor for the cruise computer on those vehicles is located behind the dash, inline with the speedo cable, about a foot from the gauges. That speed sensor uses 5/8" thread on one end, so there will be an adapter from the factory that connects it to the vehicle's 7/8" cable. The one time I tried to get one though, the cable was so rusty that I couldn't get the adapter out without destroying it... you might have better luck though.
Also, you can call up www.speedometersolutions.com and order a 5/8" to 7/8" adapter for like 6 bucks.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #156 of 157 Old 04-12-2010, 02:44 AM
RookieJeeper01
1987 YJ Wrangler
Great Thread! Just finishing up my 4.2 to 4.0 head and MPI swap. Have some questions about the wiring, but need to dive in a little more first.
RookieJeeper01 is offline
post #157 of 157 Old 04-12-2010, 08:11 AM Thread Starter
cevans87
1992 XJ Cherokee
well let me know, i also have another thread that goes into a little more detail...
http://www.jeepforum.com/forum/f12/4...ll-one-983815/
cevans87 is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Gathering parts for Axle swap, SOA, and V8 swap... tank29 YJ Wrangler Technical Forum 7 12-03-2009 02:42 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
