Doesn't like starting "fuel pump?" - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Doesn't like starting "fuel pump?"
1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,Zone Offroad Body and Suspension Lift Kits, Brackets, Disc
Unread 10-15-2001, 12:24 PM   #1
jmsjeep
Most of the time I need to pump the gas pedal to get it to start, without pumping it just keeps turning over and spuddering. Runs fine once it starts.
I have a throttle body injection system
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline   Reply With Quote Quick reply to this message
Unread 10-17-2001, 11:08 AM   #2
jmsjeep
I'm thinking about changing the fuel pump, not the quickest job. So if this does not make since please advise me.
Unread 10-19-2001, 02:33 PM   #3
AJ
You're not providing a whole lot of info there. I'd check your fuel pressure and make sure that the pump is pressurizing the system prior to starting the engine. Pumping a fuel injection system doesn't do anything as far as introducing gas into the engine as there is no accelerator pump like in a carb. That's why you can't flood an injected engine. What it probably is doing is telling the computer that it's under throttle and
making it inject fuel. Check your tps to make sure it's in good repair, although a bad tps usually make for rough idle and poor power.
AJ is offline   Reply With Quote Quick reply to this message
