Doesn't like starting "fuel pump?" - JeepForum.com
post #1 of 3 Old 10-15-2001, 11:24 AM Thread Starter
jmsjeep
Most of the time I need to pump the gas pedal to get it to start, without pumping it just keeps turning over and spuddering. Runs fine once it starts.
I have a throttle body injection system
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
post #2 of 3 Old 10-17-2001, 10:08 AM Thread Starter
jmsjeep
I'm thinking about changing the fuel pump, not the quickest job. So if this does not make since please advise me.
jmsjeep is offline
post #3 of 3 Old 10-19-2001, 01:33 PM
AJ
You're not providing a whole lot of info there. I'd check your fuel pressure and make sure that the pump is pressurizing the system prior to starting the engine. Pumping a fuel injection system doesn't do anything as far as introducing gas into the engine as there is no accelerator pump like in a carb. That's why you can't flood an injected engine. What it probably is doing is telling the computer that it's under throttle and
making it inject fuel. Check your tps to make sure it's in good repair, although a bad tps usually make for rough idle and poor power.
AJ is offline
holley "blue" fuel pump jeepin1995 YJ Wrangler Technical Forum 6 03-15-2009 07:59 PM
"Fuel pump won't come on, runs fine when connected to 12v " SeanVelarde YJ Wrangler Technical Forum 6 12-16-2008 09:07 PM
Trouble Starting...Fuel Pump? jim7966 TJ Wrangler Technical Forum 3 10-27-2007 04:48 PM
Fuel pump relay rapid "pop" ? YJ_ YJ Wrangler Technical Forum 5 10-25-2006 03:23 PM
"Chugging" while Stopped......Fuel Pump?? TJnTN TJ Wrangler Technical Forum 2 04-02-2004 03:39 PM
