Does your '88 have an accessory position? - JeepForum.com
post #1 of 9 Old 06-24-2013, 02:58 PM Thread Starter
bpounds
bpounds's Avatar
My '88 owners manual speaks of an accessory position on the ignition switch, but mine won't turn past the locked position. Wondering if maybe they don't have it. My Wrangler is probably the most base model. No door locks, etc.
Should it have it? Should I try harder and force it? Take the column apart?
bpounds is offline
post #2 of 9 Old 06-24-2013, 03:00 PM
baritone_mike
Mine has off, then a click forward is the ignition on, then one more forward starts the jeep. If you push in then turn the key towards you from the off position it is the accessory position.
I would assume mine is absolute base model, 4 banger, no center console, soft top, and half doors with no locks, I don't even think it had full carpet in it. The only option in it that I can think of is an ash tray and cigarette lighter (which may have been standard?)
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #3 of 9 Old 06-24-2013, 03:05 PM
jokerchief462
Accessory is the same as on. Nothing is broken mine does the same. No traditional accessory past off.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 9 Old 06-24-2013, 03:09 PM
baritone_mike
So is mine broken? I have an accessory position, I use it every day to listen to the radio in the parking lot. Push in and turn one click towards you from off.
post #5 of 9 Old 06-24-2013, 03:34 PM Thread Starter
bpounds
bpounds's Avatar
My ignition pushes inward, like I would expect it to do for accessory. But it refuses to turn, and I don't want to break something that might be working normally.
So we're still not sure.
bpounds is offline
post #6 of 9 Old 06-24-2013, 03:45 PM
Old4X
1990 CJ7
Wranglers have accessory position. ON is NOT the same. In the "ON" position, the ICM is powered up. You will burn up your ICM if you leave the power on it, not running, for more than a minut or so.
If you can't get to the acc spot, your lock is worn out or the ignition switch is out of adjustment.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 9 Old 06-24-2013, 04:46 PM
baritone_mike
I am 100% sure a 88 Wrangler has an accessory position.
Have you tried jiggling the key around a little? The ignition may be worn and the key is not in the right place?
post #8 of 9 Old 06-24-2013, 05:29 PM Thread Starter
bpounds
bpounds's Avatar
Yeah, I've wiggled it every which way. I guess I will have to open up the column and take a look. I might just replace the lock cylinder, because the key is in pretty bad shape. Thanks for all the replies.
bpounds is offline
post #9 of 9 Old 07-15-2013, 06:52 PM
Michaelgoesrawr
I didn't know the ACC position was there. Went out and gave it a shot and it works.
Michaelgoesrawr is offline
