Does this wire ring a bell? - JeepForum.com
post #1 of 3 Old 04-01-2010, 10:57 AM Thread Starter
I8AHUMR
I was poking around and found this connector unhooked. Wondering if it looked familar to anyone before I go ripping apart the dash. Any possibility it's for one of the AC controls? My AC randomly quit working last summer which is why I ask. In the same general area. Has 12V on it with key on
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #2 of 3 Old 04-01-2010, 11:17 AM
timatoe
timatoe's Avatar
Looks like the 12v line for the cigarette lighter, just slides on the end of a bolt looking piece on the back. Although that wire should be violet, but may have been switched at some point.
timatoe is online now
post #3 of 3 Old 04-01-2010, 04:51 PM
Neo1130
2015 JK Wrangler
Yep, that is for the cig lighter. Because you have A/C, the ashtray has been moved and that is the left over cig lighter.
Neo1130 is offline
2 wire LEDs to 3 wire conversion (write up) zachjf TJ Wrangler Technical Forum 149 04-17-2017 11:57 AM
Anyone ever mastered the 3 wire turn signal rewired to the 2 wire LED Rippers TJ Wrangler Technical Forum 28 06-08-2016 01:29 AM
speed sensor wire and reverse wire for aftermarket navigation system Stacydmcc JK Wrangler Technical Forum 1 11-06-2009 03:07 PM
battery wire harness green wire? brinoff YJ Wrangler Technical Forum 4 03-07-2009 04:25 PM
Snap Ring/Retaining Ring Pliers SYE Install mking7 TJ Wrangler Technical Forum 7 09-29-2004 10:55 AM
