Does the temp gauge sometimes go bad? - JeepForum.com
post #1 of 9 Old 04-13-2009, 07:57 PM Thread Starter
wildbadbill
It's stuck on cold and raises just a tad.I did replace the sensor and still the same...
wildbadbill is offline
post #2 of 9 Old 04-13-2009, 08:17 PM
Old4X
1990 CJ7
Pull your gauge cluster and clean the ribbon cable at the connector.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 9 Old 04-13-2009, 08:20 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
WARNING WARNING DISCONNECT YOUR BATT BEFORE REMOVING CENTER GAUGE CLUSTER WARNING WARNING
You can easily fry the circuit board while removing it. It can ground/short to the dash frame.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 9 Old 04-13-2009, 08:26 PM Thread Starter
wildbadbill
thanks guys,love this board...
post #5 of 9 Old 04-13-2009, 08:32 PM
asbury
what sensor did you replace , the one onthe back of cyl head is for the gauge
JEEP NAKED !!
asbury is offline
post #6 of 9 Old 04-13-2009, 08:37 PM
JACFF7
1987 YJ Wrangler
is there more than 1 sensor?
87 YJ 4.2l
nuttered,4bbl Holley, Offy int, pacesetter header, down tube,
2-1/2 out back. hei.. Clear round 24 diode taillights.
JACFF7 is offline
post #7 of 9 Old 04-13-2009, 08:41 PM
asbury
on my 95 with a 2.5 there is one on thermostat housing and the one on the cyl head ,,, the one on thermostat is called temp sensor the one in cyl head is called temp switch,,the switch controls the gauge
JEEP NAKED !!
asbury is offline
post #8 of 9 Old 04-13-2009, 08:41 PM
Old4X
1990 CJ7
Yes, there is another on the left side of the block, about in the middle, it isn't for the gauge. (on 4.2 engine. The 4.0 has 2 as well, but I have no idea where the other one is).
Old4X is offline
post #9 of 9 Old 04-13-2009, 08:51 PM Thread Starter
wildbadbill
well,now I'm confused-will look for the one on the back tomorrow....
89 YJ Temp gauge DOA monkeyhouse YJ Wrangler Technical Forum 3 09-21-2009 10:59 AM
Is this temp normal? Temp Gauge Pic !!! Thunderstrike TJ Wrangler Technical Forum 23 06-26-2007 09:01 PM
temp gauge 1992JeepYJ YJ Wrangler Technical Forum 5 10-30-2006 06:12 PM
temp gauge 1992JeepYJ YJ Wrangler Technical Forum 6 09-28-2006 10:35 AM
temp gauge brad2bw YJ Wrangler Technical Forum 4 08-31-2004 09:27 AM
