Does my YJ exhaust have a donut gasket - JeepForum.com
post #1 of 9 Old 02-23-2007, 05:56 PM Thread Starter
howellru
howellru's Avatar
So it warmed up enough down here to finally go topless. In doing so I noticed for the first time my exhaust is farting something aweful. My mechanic friend said I likely needed to replace the donut gasket at the exhause manifold.
So, I called my local O'riely's parts store and they have no listing to a donut gasket on my 4.2L. Is that true? The exhaust bolts directly to manifold w/out any sort of gasket? I haven't had a chance to dixconnect the exhaust line, but was thinking/hoping maybe there was some universal gasket available so I dont have to involve an exhast shop.
Look forward to hearing back from you guys, cause me not like to fart around town.
Welcome to my midlife crisis. ;)
'89 YJ Wrangler, 4.2L, MC2100 Nutted Carburator
howellru is offline
post #2 of 9 Old 02-23-2007, 06:17 PM
Burnerman
Burnerman's Avatar
Nope.. no gasket. I have to retorque the nuts every so often.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 9 Old 02-23-2007, 06:20 PM
Kimoscout
Same thing here on my 87, reassess...retorque. No donuts.
Kimoscout is offline
post #4 of 9 Old 02-23-2007, 06:38 PM
Think
Think's Avatar
same thing on my 2.5. I thought the donut was gone too, and I hate exhaust work, so it took it to the shop. like 20 bucks later, I learned the bolts come undone every so often.
95 YJ 2.5 litre + broke student with a TON of debt = slightly more than stock Jeep that is rusting out
I'm not a vegetarian because I like animals, I'm a vegetarian because I hate plants
Think is offline
post #5 of 9 Old 02-24-2007, 05:48 AM
VT2BAD4U
May want to check the pulse air tube that is attached to the down pipe, they tend to rot off too.
VT2BAD4U is offline
post #6 of 9 Old 02-24-2007, 08:32 AM Thread Starter
howellru
howellru's Avatar
The pulse air tube rotted off last year any I've clipped it off behind the transmission and plugged it to muffle the noise. I've thought about running an new exhaust from the manifold back. Nothing fancy; pipe, not cat, and a cheap muffler. Anyone have an idea what that'd run me?
howellru is offline
post #7 of 9 Old 02-25-2007, 09:18 AM Thread Starter
howellru
howellru's Avatar
So I tackled my exhaust yesterday and after dousing the bolts with Freeze Off penetrant http://www.crcindustries.com/marine/...x?PN=05002&S=Y I finally got one to snug up pretty tight. Unfortunately I couldn't get to the innet nut. It's blocked too much by the pulse air tube to get anything other that a wrench over it. And, i couldn't apply any torque worth a darn to it with just a wrench. What do you guys use to tighten that inner nut?
Looking on the brighter side, my Jeep's farting is cut in half. Still, it's sort of hard to exude coolness cruising around town in a farter, even if it's half as loud as it was before.
howellru is offline
post #8 of 9 Old 02-25-2007, 09:38 AM
Burnerman
Burnerman's Avatar
I used a 9/16 socket on my 24" extension and was able to get it laying under the heep. I pulled it all off yesterday and crimped off the air tube hook up on the down pipe and cat. A swivel socket can get in there. I just gotta finish welding up the joint to the rusted off cat flange and mine will be nice and quiet. A new exhaust front to rear is up comming this spring.
96 ZJ.
post #9 of 9 Old 02-26-2007, 03:47 PM Thread Starter
howellru
howellru's Avatar
I was thinking a swivel head may be the only way to get there. I was thinking of cutting off the pulse air tube at the manifold. It broke off a while back where it crosses the transmission. I wasn't sure I could plug the hole though and would still be farting.
howellru is offline
2000 TJ Exhaust donut gasket pharmacist25 TJ Wrangler Technical Forum 12 11-22-2015 03:21 PM
Please Show Me Where The Exhaust Donut goes Danegerous TJ Wrangler Technical Forum 3 04-17-2009 08:45 PM
Exhaust leak at downpipe? Need a donut? cmorganf64 TJ Wrangler Technical Forum 1 03-11-2008 06:37 AM
HELP- Exhaust man gasket or not? Crispin YJ Wrangler Technical Forum 3 05-06-2007 03:36 PM
Donut Gasket 99 wrangler two4zero TJ Wrangler Technical Forum 3 04-16-2005 12:10 PM
