Does anyone have a TF999 pulled out - JeepForum.com
 1Likes
  • 1 Post By bck4more
post #1 of 12 Old 04-24-2017, 07:09 PM Thread Starter
bck4more
1987 YJ Wrangler
Rally needing a favor if someone has there transmission pulled out if you could pull the dipstick tube out of the transmission and measure how far the dipstick sticks out of the bottom please. Thank you in advance
1987 4.2 automatic, 33" Pro Comp, 2100MC, nuttered, SOA, SYE,TW driveshaft
bck4more is offline
post #2 of 12 Old 04-25-2017, 02:12 PM
jp19
I'll take a look tonight. I just installed mine but i think i can get the dipstick tube out with it in. I'll let you know. -JoeP
jp19 is offline
post #3 of 12 Old 04-25-2017, 02:58 PM Thread Starter
bck4more
1987 YJ Wrangler
Awesome thanks a lot.
bck4more is offline
post #4 of 12 Old 04-27-2017, 06:18 PM Thread Starter
bck4more
1987 YJ Wrangler
Bump
bck4more is offline
post #5 of 12 Old 04-30-2017, 05:20 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
i just pulled mine last weekend, will try to measure tomorrow after work. PM me if i forget and you havent found answer
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #6 of 12 Old 04-30-2017, 09:55 PM Thread Starter
bck4more
1987 YJ Wrangler
Sweet thanks a lot
bck4more is offline
post #7 of 12 Old 05-02-2017, 06:45 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
ok i measured the dipstick was 5/16" or maybe 11/32 past end of tube(which seems a little ridiculous IMO) but thats what it was. Sorrry it took so long
The_Goob is offline
post #8 of 12 Old 05-02-2017, 08:26 PM Thread Starter
bck4more
1987 YJ Wrangler
Awesome awesome man I appreciate it very much
The_Goob likes this.
bck4more is offline
post #9 of 12 Old 05-03-2017, 03:02 PM
bob6987
On a 94 tf999 i have its about 13/16"
1991 YJ, 4.0, 6" lift, 40" tires, full cage, dana44/ford 9, detroit locker, 5.38 gear
2012 JKU
bob6987 is offline
post #10 of 12 Old 05-03-2017, 05:14 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
92 and up its usually a 32rh, essentially the same trans but with a lockup converter. maybe there is a slight difference in dipstick length(thats what she said)
The_Goob is offline
post #11 of 12 Old 05-03-2017, 07:07 PM
Chrisnvegas
Chrisnvegas's Avatar
Not all 32RH's are lockup. My 92' is a non lockup.
It's kind of random.
I also had a 999 on my CJ7 that had a lockup.
The 8 thousand threads that say the lockup is the difference, they're wrong.
From Moses Ludel: "Many of the parts do not interchange between the 30/32RH and earlier 904 or 999 units. There are case, fluid passageway, valve body and shaft components that distinguish the 30/32RH series transmissions from the 904/999 types. If rebuilding a 30RH or 32RH unit, use the components designed for each of these units."
http://www.4wdmechanix.com/moses-lud...light-service/
"Auto racing began 5 minutes after the second car was built."
Henry Ford
Chrisnvegas is online now
post #12 of 12 Old 09-19-2017, 10:22 PM
mbeirne
According to the information in the Moses Ludel link the TF999 has a lockup. And my 1980 CJ7 has a TF999 and a lockup.
mbeirne is offline
