does anyone have pics or diagrams of 4wd vaccume lines - JeepForum.com
post #1 of 8 Old 01-23-2006, 02:38 PM Thread Starter
rolledthatho
i just bought my jeep, i havent messed with the vaccume lines however, my 4wd has gotten very hard to engauge and disengauge, and i see a few empty vaccume hoses around in my engine bay....
just wondering if anyone had any pics or diagrams of which hoses that have anything to do with the 4wd also where and how can i check the fluid for all that
rolledthatho is offline
post #2 of 8 Old 01-23-2006, 03:00 PM
ajnoor4
Underneath your hood should be a vacuum diagram. They also have one in the Haynes Manual. Not the greatest for the 4wheel drive though. For your transfer case you will see 2 plugs. The lower is the drain and the upper is the fill. Remove the upper (who ever checked mine before I bought my jeep must have put it on with an impact gun!!!) and the fluid should be at the top of the hole (if it drips out a little thats fine) If not add some tranny fluid. With the diffs it's the same thing (just make sure you use gear oil). Use a 3/8" drive ratchet to remove the plugs.
ajnoor4 is offline
post #3 of 8 Old 01-23-2006, 03:21 PM
Fenix85182
Fenix85182's Avatar
Yeah, the fact that it's shifting into 4x4 should eliminate the vaccuum lines. I'm fairly certain that's a hit or miss.
I hate adding fluid to my transfer case, though I should again because the rear seal is shot and it leaks all over the place. I think the fill plug is some crazy socket size, some like 1 1/16". I never can get it right the first time.
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #4 of 8 Old 01-23-2006, 03:34 PM
naviathan
30mm actually
The easiest way I've found is to use a gear oil top (you know the pointy one) on the end of a bottle of ATF. Yes it does fit even though it doesn't look like it.
SOLD - Maybe I can afford this game when I'm old and rich.
naviathan is offline
post #5 of 8 Old 01-23-2006, 04:17 PM
ODJeep
If you PM me with an e-mail address I can send you a good vac. diagram of the 4wd system.
ODJeep is offline
post #6 of 8 Old 01-23-2006, 08:59 PM
wranglerkid16
send it to me too, lol, joek4784@yahoo.com
wranglerkid16 is offline
post #7 of 8 Old 01-23-2006, 10:28 PM Thread Starter
rolledthatho
hey odd jeep, that would be awesome!
rolledthatho@hotmail.com
post #8 of 8 Old 04-18-2010, 10:42 AM
CrushJeep
yeah send it to me too if anyone above has it... crush.mark@gmail.com
CrushJeep is offline
home made posi lock- vaccume lines? xcnick38 YJ Wrangler Technical Forum 2 01-15-2009 11:10 PM
Vent problem, vaccume leak? 03 rubicon badassjeep04 TJ Wrangler Technical Forum 2 12-23-2008 10:05 PM
front axle vaccume problems (the usual) WranglerWheeler YJ Wrangler Technical Forum 8 11-17-2008 09:10 PM
No front vaccume after removing hoses need help daddoty YJ Wrangler Technical Forum 2 02-18-2007 10:09 AM
fixed some vaccume lines but still no 4wd vball1socr4 YJ Wrangler Technical Forum 3 07-10-2003 06:26 PM
