Dodge durango steering box in a YJ - Page 9 - JeepForum.com
post #121 of 144 Old 05-03-2013, 07:37 AM
Cyrus1983
I just did this to my 88 YJ sport and boy I couldn't be happier... Great thread I was able to do my swap using all of the info on this thread...
I live I ride I am Jeep
Cyrus1983 is offline
post #122 of 144 Old 10-22-2013, 07:04 AM
superduty59
Originally Posted by PA_YJ19 View Post
Thought I would share that while looking for a Durango steering box I found another option. It's called the zq8 steering upgrade for s10s and blazers, it is the gear box from the Chevy s10 extreme. It looks exactly like the Durango box but has a z imprinted on it. I got mine out of a gmc Sonoma but they r mainly found on s10's. I have the same amount of turn lock to lock but this box has a much quicker ratio, 12:1 or something like that. My wheel now pulls back to center when a turn n all around seems way smoother. It also only has 3 bolt holes to mount it just the same as the Durango. I'm not sure if the piston is me larger but I no my jeep steers like a car on the road now n I'm very satisfied. 30 bucs at the local pick n pull in my town.
I know this is an older thread but was thinking about doing this swap. It sounds like the S10 extreme box may be a better box then the Durango swap.
superduty59 is offline
post #123 of 144 Old 10-22-2013, 08:55 AM
PA_YJ19
It worked for a short period of time but my pump was bad and in turn ruined the s10 extreme box n I could not find another used one. It is the same size bore inside as our stock one(I took it appart) but with a much quicker ratio. It would work very well for street driving and did until my pump but the dust. I ended up using a Durango box and upgrading my pump to one from a WJ 4.7l because is has 500psi higher than all te other stock jeep pumps. Works like a charm, I would def give the extreme one a try if u can find one used, brand new they r a bit pricey...
PA_YJ19 is offline
post #124 of 144 Old 11-19-2013, 08:29 PM
WESTBOUND
Will this power steering mod work on a 4 cylinder YJ? A buddy wants to do this over X-mas break in a month.
I did this mod on my 2001 TJ and I love it. All my Jeeping club has done it. I replaced the pump too along with the hoses and put a power steering cooler and a filter on too. The first power steering gear box I put on started leaking immediately and went down hill too the point of fluid pouring out so I had to replace it. The second Auto Zone 98 Durango gear box has been perfect. They exchanged it without hassle.
WESTBOUND is offline
post #125 of 144 Old 11-19-2013, 08:40 PM
PA_YJ19
Sure will, works on both.
PA_YJ19 is offline
post #126 of 144 Old 12-11-2013, 02:26 PM
Benzfrd
This post is awesome. Will be doing this soon
Benzfrd is offline
post #127 of 144 Old 03-17-2014, 05:51 PM
hottubsplus
Awesome upgrade. I wish I had heard of this last year before I installed rebuilt stock yj box. Tryed adjusting it to get rid of slop but just never felt good. Did their Durango swap last week and 200% better than stock. Running 35s and feels great.
hottubsplus is offline
post #128 of 144 Old 03-18-2014, 10:52 PM
sardog211
So I have read this entire thread, what about the one extra bolt that the YJ has that the Durango does not? Does that make a difference support wise? I would really hat to have my steering break or something happen because of a missing bolt. I want to do the mod but want to hear what others did about this.
sardog211 is offline
post #129 of 144 Old 03-19-2014, 08:15 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
It's not a concern if you use the 4 bolts. Their is a bracket that goes between the box and frame. That bracket has four bolt holes in it. The YJ box has 4 holes too. The Durango box only has three. You obviously use the 3 for the box, but the trick then is to use a 4th bolt and nut to fill the last hole for the bracket to the frame. The bracket/frame connection is then the same as it was in a stock YJ setup.
I also chose to add a cross-bar too, from the nose of the box at the pitman to the right side frame rail. It's an easy bolt of a fabbed bar if you also don't have a swab bar and use the sway bars right side bracket.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #130 of 144 Old 05-02-2014, 12:09 PM
cmartyj93
Speaking of the steering box bracket...
I am doing this install after patching the frame in the area of the steering box and I'm trying to reinstall the steering box bracket. There is a small hole in the surface that mounts to the bottom of the frame in addition to the two big bolt holes. Does anyone know what that little hole is for? I want to make sure I don't ignore it and find out much later on that it was important.
Thanks for the help
Here's a pic of what I'm talking about
Check out my build thread:
cmartyj93 is offline
post #131 of 144 Old 07-16-2014, 09:51 AM
deogsxr
will be doing this soon, great thread!
*1995 YJ, 4.0l 5 speed.
*2006 Dodge 2500 5.9l Cummins Twin Turbo
*2010 Infiniti G37xS (*FOR SALE*)
deogsxr is offline
post #132 of 144 Old 01-16-2015, 08:21 AM
jmyr
1994 TJ Wrangler
Figured I'd bring this thread back instead of starting a new one but what have you guys been using for pitman arms? I have one for a YJ with a 4" lift but its 3-4 teeth short and its allowing for more play in the wheel than I'd like. Durango pitman arms have a joint on the other end so they wouldn't work.
So... suggestions?
Also my current pitman arm isn't wallowed out, worn down, broken or anything like that. I've also added an extra washer because I was running out of thread and that helped a little bit.
jmyr is offline
post #133 of 144 Old 01-16-2015, 09:14 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
I used to have a dropped YJ pitman on the YJ box. After doing the Dbox swap I didn't have the same throw (max drag link motion distance). I got a WJ pitman, which is 4/3" longer for more throw, and I got the steering back as it was. But, to get the WJ pitman on, you have to grind out the flats in the new arm so it can slip onto pitman shaft in any orientation, centering it properly of course.
In my case I lost the drop pitman aspect because I got a used stock WJ pitman. That was fine with me as the rest of the suspension had evolved since I got the YJ drop pitman, and the drop wasn't really needed any longer.
Web Admin for
post #134 of 144 Old 04-29-2015, 03:50 AM
drod086
Just did this upgrade. Not too complicated. Broke the return line going to the reservoir (damn rust) the un-used 4th hole bothers me. I feel like I need a brace to stiffen it up. Any suggestions?
drod086 is offline
post #135 of 144 Old 04-29-2015, 08:04 AM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Absolutely put a bolt through the unused hole to better hold the bracket to the frame.
Web Admin for
Is a Dodge Dakota steering box the same as the Durango? rikkards TJ Wrangler Technical Forum 23 11-08-2015 10:40 PM
Replacing jeep steering box with a Durango Steering box? Beefstew TJ Wrangler Technical Forum 171 05-22-2012 09:17 AM
durango steering. 99 durango 00 tj pitman arm slafferty TJ Wrangler Technical Forum 0 09-05-2009 02:28 PM
Will durango steering pump work with the steering box. sitdwnandhngon YJ Wrangler Technical Forum 0 08-13-2008 08:20 PM
Dodge Durango PS box replacement? PopGoesTommy TJ Wrangler Technical Forum 4 08-08-2005 01:03 AM
