Dodge durango steering box in a YJ - Page 6 - JeepForum.com
post #76 of 144 Old 05-10-2010, 03:09 PM
ritjobbie
Originally Posted by HARLEYX2 View Post
How many people have ripped a Durango box off of the frame because it only has 3 ears?
I've wondered this myself. Bump.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #77 of 144 Old 05-10-2010, 04:06 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I can say in the time I have been on this forum (way too much for too long), there has never (ever) been a report of that. If I recall correctly (have not done the upgrade yet), the box uses a cast bracket between it and the frame, and you reuse the same Jeep bracket. There are two sideways bolts through the frame and bracket and into the box. Then there are two other bolts on a Jeep box and one on a Dur box bolting the box to the bracket. Last, there are two bolts upward through the bracket into the bottom of the frame. So, the frame sees the same four bolts as always.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #78 of 144 Old 05-10-2010, 04:14 PM
brunolinski
I second that Don. Haven't heard of a single "ripped off" box. I have one and just to be safe I threw a tack weld on it to make sure nothing wiggled loose. Best steering mod I have made yet!
brunolinski is offline
post #79 of 144 Old 05-10-2010, 04:17 PM
HARLEYX2
1987 YJ Wrangler
I have heard of several that have broke on another board but was wondering everyone heres opinion. Thanks
HARLEYX2 is offline
post #80 of 144 Old 05-10-2010, 05:15 PM
JeeperDon
JeeperDon's Avatar
I tend to look around at all the boards and just follow the advice of the one that has the answer I want.
Web Admin for
post #81 of 144 Old 05-10-2010, 05:16 PM
northjeep
Jeep parking ONLY
northjeep's Avatar
did the mod.
Only 3 bolts.
No bracket that don is talking about on my heep.
I would not trust it without my steering brace (which goes from the pass frame rail to the snout of the box) as I have seen stock boxes with the 4 bolts ripped off.
-NorthJeep - >> Just Enough Essential Parts
northjeep is offline
post #82 of 144 Old 05-10-2010, 05:27 PM
JeeperDon
JeeperDon's Avatar
Originally Posted by northjeep View Post
did the mod. Only 3 bolts. No bracket that don is talking about on my heep.
Here it is from the FSM. It does not show all the bolts in the pic, but two go through frame and two into frame from below. This particular box shows 3 box ears like a Durango. The 'adapter' allows for four. It looks like the upper rear through bolt would hit no box tab, so I'd put a nut on it to hold the adapter on with 4 bolts, making normal forces to the frame.
Web Admin for
post #83 of 144 Old 05-11-2010, 07:20 AM
northjeep
Jeep parking ONLY
northjeep's Avatar
Oh that "bracket".
Yeah the steering brace is still where all the sheer force is going through my setup...and that's fine with me.
4 bolts on the factory adapter would probably carry you through tire sizes up to 33...but like I said...I've seen them rip off. I guess it depends on the health of the frame there too. I know it's a rust spot on these frames.
Don't you love subjectivity?
post #84 of 144 Old 05-11-2010, 06:53 PM
crazyquadder
Know the durango box drops directly in. 0 modifications needed. And the 3bolts line up correctly. Does the yj skid plate and steering brace still line up(aftermarket of course). Thanks hope to hear from you
crazyquadder is offline
post #85 of 144 Old 05-12-2010, 08:30 AM
northjeep
Jeep parking ONLY
northjeep's Avatar
From my experience the brace is a direct fit.
Dunno about the skid plate but I remember hearing it's a direct fit too.
post #86 of 144 Old 05-14-2010, 05:12 AM
89CoolJeep
Junior Member
So there is 0 modifications needs its a direct bolt up. Just unbolt old steering box leaving mount in their and just put durango onw directly in. And whay years was it for
89CoolJeep is offline
post #87 of 144 Old 05-14-2010, 08:44 AM
northjeep
Jeep parking ONLY
northjeep's Avatar
Seriously I try never to flame. But dude...this was covered on the very first post of this thread.
1999 durango v8 non-plow.
post #88 of 144 Old 07-09-2010, 05:34 AM
bfaneros
TJ with 39.5" iroks, Ripped the box smooth of last night. Thank god I was still in my neighbor hood less than a block from the freeway.
bfaneros is offline
post #89 of 144 Old 07-18-2010, 09:25 AM
skimsurf
sounds good since my steering box just sh*t the bed...since its sunday, im kinda screwed till tomorrow, but I got a list of junkyards to call. Thanks!
skimsurf is offline
post #90 of 144 Old 08-02-2010, 07:01 PM
g4x4xgeoff
so what was the final parts list and cost?
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Is a Dodge Dakota steering box the same as the Durango? rikkards TJ Wrangler Technical Forum 23 11-08-2015 09:40 PM
Replacing jeep steering box with a Durango Steering box? Beefstew TJ Wrangler Technical Forum 171 05-22-2012 08:17 AM
durango steering. 99 durango 00 tj pitman arm slafferty TJ Wrangler Technical Forum 0 09-05-2009 01:28 PM
Will durango steering pump work with the steering box. sitdwnandhngon YJ Wrangler Technical Forum 0 08-13-2008 07:20 PM
Dodge Durango PS box replacement? PopGoesTommy TJ Wrangler Technical Forum 4 08-08-2005 12:03 AM
