Dodge durango steering box in a YJ - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Dodge durango steering box in a YJ
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 10-13-2009, 10:16 AM   #61
czjeeper
I've had the Durango box and RR HD steering kit in for about 2 weeks now.
This turned my heep into a nice steering heep!
I highly recommend either or both!
US Army combat vet
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area?
Check 'em out! Piston's Wild Motorsports Club
Click here for 2.5L AX5 to AX15 swap
czjeeper is offline   Reply With Quote
Unread 10-30-2009, 12:17 AM   #62
jerseyrider1119
will a 2000 durango steering box work?
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
I only read the pictures!
95 Rio Grande- 4" Pro Comp lift, 235x75r15 on stock Alloys, Boomerangs, Piolet Trail Lights, Hurc'd, No Sways or Trac, Custom Under Dash Wiring Harness
jerseyrider1119 is offline   Reply With Quote
Unread 10-30-2009, 05:45 AM   #63
brunolinski
NO. It must be 98 or 99 only, from a 4wd v8 Durango. You should look for a 95-99(?) Grand Cherokee with a stock pitman arm at the same time. It has a stock 4" drop and fits perfectly on the YJ if you are lifted up.
brunolinski is offline   Reply With Quote
Unread 01-21-2010, 02:01 PM   #64
icepack212
I just did this upgrade, easiest upgrade in the world! I have a 2000 TJ, the old gear box was leaking and took longer to take off than to install the new Durango box! I went to Autozone and dropped my old TJ gear box without the idiots there recognizing the difference between the TJ and Durango gear boxes. I asked them for a 1998 Durango 4x4 with a 5.2 V8. For about $186.99 (after my core deposit) I got a new box, and its awesome! This post needs to be a sticky! Direct bolt in.....piece of cake.
icepack212 is offline   Reply With Quote
Unread 01-24-2010, 01:18 AM   #65
Marine_Mike
Just an update... I'm now running 89 waggy d44s with 36x12.5x15 super swamper bias. The durango box hasn't flinched one damn bit. Best cheap upgrade done yet.
Marine_Mike is offline   Reply With Quote
Unread 02-24-2010, 01:25 PM   #66
thiat302
Guys,
If you want to do this, nows the time- go to Advanceautoparts.com- Its 179.99 (+$75 core) but if you put in coupon code BIG20- you get $20 bucks off- making it $160- hell of a deal- Im about to buy mine now- lol
Figured Id share the savings-
Normally I dont shop with advance because they always screw sh*t up- but I can always return it if it looks wrong when I go to pick it up from the store-
**Just Bought it -Out the door for $251.54- which Ill get $75 back when I return CORE on Sat. after install for a grand total of $176.54**
Your pockets better run deep if you want to own a Jeep
thiat302 is offline   Reply With Quote
Unread 04-15-2010, 12:59 PM   #67
CreepyCrawler95
just curious but why does it have to be 4x4
CreepyCrawler95 is offline   Reply With Quote
Unread 04-15-2010, 01:27 PM   #68
89saharayj
since there is only 3 bolts in the durango box, do i NEED a steering brace or can it just wait till my funds allow it?
and can i adjust the stock drag link enough for the swap?
1989 jeep yj sahara sand tan color, 3.5bds lift 33tires 8.8rear 4.11 gears. revolvers
89saharayj is offline   Reply With Quote
Unread 05-02-2010, 06:58 PM   #69
scooter18155
1983 CJ7
just wanted to chime in here as i put a durango gear box on with the rugged ridge hd steering, borgeson steering shaft, a gear box brace, and a gear box skid plate. It all fit nicely but the shaft that goes from pitman arm to pass side tie rod had to be about the shortest ya can get it in order to keep the steering wheel where it needs to be. I never ran the rr hd kit with stock stuff so not sure how much play room ya got there but judging by length of tie rods and the bar length they probably should have made the bar shorter a lil bit to allow for more adjustment.
scooter18155 is offline   Reply With Quote
Unread 05-09-2010, 08:01 PM   #70
ringster
Gotta do this on a 90 YJ 4 cyl
Just bought a 90 YJ for my 18 year old son (I've got an 89) and the steering box is leaking. As far as I can tell everything is stock. Will the 98 Durango box work on this? and if so is it really worth it? I can get the remanufactured Jeep part for 133 (plus core), the Durango part is running $180, plus core at Advanced. So will it really make that much difference for the extra $50?
Thanks in advance, this is an awesome forum, especially for new jeep owners!
ringster is offline   Reply With Quote
Unread 05-10-2010, 04:22 AM   #71
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
Originally Posted by ringster View Post
... is it really worth it?
For most people, it's completely unnecessary and you won't know the difference. If you plan large tires and a lot of off-roading, it will just insure better strength. I'm still on the original box at 165,000 miles and years of wheeling with 35" tires. I plan on swapping my old one out soon (just because old 'last leg' stuff on my Jeep scares me in the woods) and will likely do the Durango box, but I do wheel a lot with larger tires.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote
Unread 05-10-2010, 04:24 AM   #72
GRYDE001
I assume you have to have power steering for this to work?
""Leave it stock, it will live longer. Just understand that its never gonna be as fast as a minivan""
GRYDE001 is offline   Reply With Quote
Unread 05-10-2010, 06:17 AM   #73
ritjobbie
Yes, this box will only work with power steering.
FWIW, my Durango box has been 100% fine with the stock power steering pump. I replaced both at the same time just because both died at the same time, but it would otherwise be unnecessary.
1995 YJ Rio Grande, 2.5L Low Output Engine
My Jeep Worklog
ritjobbie is offline   Reply With Quote
Unread 05-10-2010, 06:22 AM   #74
GRYDE001
Originally Posted by ritjobbie View Post
Yes, this box will only work with power steering.......
well, dang Now I guess I need to add power steering, geez, the list never ends
Unread 05-10-2010, 02:23 PM   #75
HARLEYX2
1987 YJ Wrangler
How many people have ripped a Durango box off of the frame because it only has 3 ears?
HARLEYX2 is offline   Reply With Quote
