Documenting the 4.0 Throttle Body onto my 2.5L - JeepForum.com
post #1 of 12 Old 04-10-2013, 05:30 PM Thread Starter
VirginJeeper
There are so many good documents out there for this swap, JEEPFORUM has some great ones, JP magazine, etc. A quick internet search yields good results. I find that even with every great writeup I have a lingering question, mainly due to lack or experience in the project itself. Please allow me to document this swap as I go and feel free to ask any questions or add suggestions along the way.
I started with finding my donor TB (Throttle Body.) I found it on an XJ with around 100,000 miles on it. I did not document the removal as I was in a pick n pull and didn't think of it. I always disconnect the battery when doing any work in the jeep as Im scared to death of frying the ECM so when doing this in your Jeep I recommend doing it, it will need to be done later anyway to reset the ECM so why not do it now and save the risk of damage. Next remove the large intake hose on the top running from the airbox and the smaller tube running to the top of the motor. Next you will have to remove the throttle cable and two plugs attached in the rear. A small flat head screw driver will facilitate this. Next remove the four bolts hold the TB on the manifold. Here is a picture of the TB removed looking into the manifold. (more on that later) Note the two plugs above and the cable below.
Attachment 605195
Now you have your donor TB you can inspect it for anything out of the normal cracks or chips in surfaces or severe burning should be avoided, don't worry about gunk and oil that is typical and will be cleaned later. Here are the side by side comparisons of the TB's. They are virtually identical with one obvious improvement from 2.5 to 4.0.
The 4.0L is the TB on the bottom of both pictures. Similar housings yet the overall interior area is Much larger in the 4.0L. It is possible to increase the size by machining out a little more from what I understand but I am just interested in a straight swap. Here is where most questions arise. You will need to swap the components from the 2.5L to the 4.0L in order for your idle to remain stable and to not create an engine light (CEL.) Yes folks they are TORX bits (star bits) and security torx bits (star bits with a raise nipple in the middle) just for good measure. So grab your set, if you dont have one by now go ahead and invest in a set, and a bag, can or handful of patience. As we all know you will need all of these for virtually any torx related removal.
The following is the same for both TB's.
I started with the IAC (Idle Air Control) valve. Remove it with the black electronic plug attached for the TB. You will disassemble it more later and clean it.
Here you can see both TB's one with the IAC removed and and the other attached. NOTE THERE IS A GASKET BETWEEN THE TB AND IAC ASSEMBLY. I broke the donor one so I was extra careful with the 2.5 one.
Here you will see some crud for sure but don't be discouraged its all a part of it. Now remove the other IAC from the other TB. Its not hard to confuse them as they are labeled but just in case you can mark them if you like. (I did as I tend to get ahead of myself.)
Now grab that patience I spoke of earlier. I had the same problem on both of the TB's when it can to removing the TPS (Throttle Position Sensor.) I think the torx screws are held in with loctite and no amount of PB Blaster made a difference. So in the end I used a small file and filed flat edges on the heads of the screws in order to grab it with a wrench. Hopefully your luck will be better but dont give up a small file will easily cut through the heads and this will not be the first time you will have to sit back and think about how you are going to get a Torx screw out.
Attached
Removed
So now you should have 2 TB's, 2 IAC's and 2 TPS's sitting in front of you. Go ahead and put the 2.5 TB, the 4.0L TPS and 4.0L TPS away. Now its time to clean what you have.
The TB will be full of crud and oil, using TB cleaner and a soft brush, go to town. Make sure to clean the opening where IAC attaches as it will be dirty and is important it is clean. See it below.
Gloves would be a good idea. I live in a condo where you are not allowed to work on your vehicle so I used a black plastic catch pan and just cleaned the inside of the TB getting what I could, I didn't clean the outside of the TB but it looks nice if you do.
Now we move to the IAC. Again we find Torx bits. Disassemble the two components carefully as there is an Oring in between the black plastic component and metal housing. Here is the assembly broken down, note the oring.
This is why the oring is important. It seals the housing to the IAC housing.
Here is the IAC cleaned up a little bit and then the housing as well.
Almost done. Just a quick pic of why we are re-using the 2.5L IAC housing. Note this little tab underneath, look at the 4.0L, yup its located differently.
The TPS needs no cleaning that I am aware of.
So now we need to start putting everything back together. I have never put a screw back into my Jeep unless it was coated in antiseize. So this is when I took a little time, cleaned the threads of all the screws and added a light coat of that magical goop. If anyone know as to why it would not be a good idea to use it in the is application please correct me. Go ahead and clean and inspect the orings you removed from both the IAC and TPS. Any cracks in either could result in loss of power and rough idle due to air leaks. So your end product should resemble this. But I'm sure yours will be much cleaner. Remember the end result should be 4.0L TB, 2.5L IAC and IAC housing and 2.5 TPS.
So at present I have a cleaned up and assembled TB ready to be put back on. Now earlier I mentioned that I would return to the manifold that I pictured. Turns out I have oil inside the manifold, the large air house from the air box and the a little oil in the airbox itself. After posting these pictures and having a discussion with fellow members, the consensus is that there is oil coming into my airbox from the CCV/PCV system (I have a 95.) I plan on cleaning all these components and then cleaning the top of the motor and cover to eliminate the oil problem. I will document this separately at a later date as unfortunately I have to take the Jeep out of my parking deck in order to do this as they are pretty strict about working on vehicles in our condo building. Be sure to inspect all of theses components and clean as needed. There are guys that leave this oil leak as it is not severe and doesn't bother them, so you decided what is best. Keep in mind what goes through the air tube dumps into the freshly cleaned TB so it makes sense to at least clean the tubes and airbox. Im going to go ahead an replace the filter as well.
Once I clean all these components this weekend I will document the cleaning and re-installation. More to come. Again any comments and suggestions are welcomed as well as corrections if I am doing this wrong. Thanks as always guys.
VirginJeeper is offline
post #2 of 12 Old 04-13-2013, 06:05 PM Thread Starter
VirginJeeper
So today was a busy day. After doing the Grand Cherokee alternator upgrade we decided to put the throttle body on the Jeep. Installation is a snap, I should note that I cleaned all the tubing and airfilter housing ahead of time. I am yet to pull the engine cover and clean the baffles in order to fix the blow by my engine seems to have. So here are some pics of the final product.
Initial feedback is positive. The throttle response is immediately improved. Acceleration is improved and smooth in gears 1-4 (i didnt get to 5th) Idle is smooth and stable, where before I had a bit of a stumble on idle. Now keep in mid that some improvement is party due to the basic cleaning of the TB itself but overall I can feel the difference in throttle response. Did it turn my 4 banger into a rocket? No. But for the time it takes to complete this the return is well worth it. Any changes I will post in the next month when I am able to drive again.
post #3 of 12 Old 04-14-2013, 12:42 AM
TDIJeep
Dude great write up.
I'm not sure, but I never have a problem with socket driven torx, but screwdrivers are not very good because you can't get solid downforce and turning force at the same time without slippage, maybe this will help you in future endavours.
Although many people look at me funny when I do this. When cleaning threads, I elevate the part upside down, and shot releasall up in the threads. you would be blown away what come out of some holes. for even better results hand thread the bolts in and out between the releasall sprayings. I find i have a lot less seized bolts then some of my friends. Anti seize is good stuff, I always use it, but i think most people use way to much.
Again man great job.
TDIJeep is offline
post #4 of 12 Old 04-14-2013, 06:49 AM Thread Starter
VirginJeeper
Thanks for the compliments i figure as much as this forum and all of you guys have done for me in keeping this Jeep running a little effort from me is long overdue. Those torx are a pain! I tried it everyway I could. The problem became it was just "popping" out when I increased downforce with a ratchet and you know what happens there! What is it you spray down the threads? Its probably something canadian that is banned here in the states as it works too well, like neproxin. Frigging FDA. I agree with you on the anti seize I've seen it dripping out of things and it makes an awful mess! Just a nice clean coat I find is always best. I'll be revisiting this after I pull the top motor cover and clean it out as I'm sure by then ill have a somewhat dirty TB.
post #5 of 12 Old 04-14-2013, 10:07 AM
Que89YJ
Great job!
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #6 of 12 Old 04-14-2013, 10:23 AM
TDIJeep
I personally use a product called releasall, i'm not sure you can get it in the states.
Actually the more i look into it, it seems to be a canadian product, damn, supporting my country without knowing.
Maybe try PB blaster i hear good things about it, it's pricey but probably cheaper for you in the states. I will by WD40 if it on sale at one of the hardware store because its not the best, but worth it when the price is right.
I just like releasall because it works and I don't feel like im spraying all my money away. Some of the other pentrators may work just as well for you but I find up here there all a bit to expensive just for pentrating oil.
Plus i use it on customers vehicles, just because for the little bit you need it's cheap enough. I never regret spraying, as the rust colour liquid that comes out always makes me smile.
If you looking for a cheap alternative to clean hardware, i use semi flat coca cola, just let it sit for a couple of days in the coke, you literally can wipe the rust right off of the threads. it actauuly suprising the first time you do it, cuz they look even worse then you wipe them and holy **** there clean.
BTW i dont work for them just like there product
TDIJeep is offline
post #7 of 12 Old 04-14-2013, 10:49 AM Thread Starter
VirginJeeper
Thanks guys. Yeah PB Blaster is generally in one cup holder and my beverage in the other!
As an interesting experiment we are cleaning the old 2.5L TB and exchanging it with the one on my buddies exact model except its a 94' I'm curious to see how big of a difference just cleaning the original one is versus exchanging for the 4.0L. I shall report back.
post #8 of 12 Old 06-23-2013, 04:35 PM
booya1967
any long term improvements? Increased gas mileage? Thanks for the info
1990 YJ Red with Black Hard top, work in progress.......
2006 TJ Silver with Black soft top
booya1967 is offline
post #9 of 12 Old 06-23-2013, 04:45 PM
92JEEPWRANGLERY
Great write up. I did the same thing on my 92 2.5 but I went one step further. I also changed the 4 fuel injectors to the yellow top Ford units. While my 2.5 is still not a rocket...for it to have 209,000 miles on it, it sure does run a lot better than it did. My buddy has a automatic 4.0 wrangler on 35's and stock gears. I might have to go lookin for him! I think it runs that much better.
92JEEPWRANGLERY is offline
post #10 of 12 Old 06-23-2013, 04:49 PM
TSEJEEPERS
Crawled and I vote sticky!
There is nothing in the stickys about this mod.
Great write up!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #11 of 12 Old 06-23-2013, 08:40 PM Thread Starter
VirginJeeper
Sorry for the delay in response. I have put about 1500 miles on the jeep since the swap. Large gains in performance have not been noted at all. This mod is done with the intent to improve throttle response and perhaps a mild gain in efficiency. The throttle response is immediately noticed. I do find that on the highway I am able to throttle up hills without hammering the pedal or downshifting to 4th. The idle is much smoother as well. So if you are looking to smoke the tires or see huge gains in mpg then this is not for you. If anything this mod opens up the air going into the motor a d forces you to do some much needed cleaning to the throttle body. For the cost and ease I would certain do it again. I will have more to report soon as my buddy's TB is in desperate need of a cleaning so we'll swap in my uber clean old one and record the results. I may even pop it back on mine just to see what difference this swap made. Thanks for all the great feedback. In case you missed it, summer is here time to get topless!
post #12 of 12 Old 11-23-2013, 03:16 PM
Mickeylad227
very nice man
Mickeylad227 is offline
